[SOLVED] Associate Z-UNO with another device
donic46
Post by donic46 »
If i want to control another device i use zunoSendToGroupSetValueCommand(), but if i want to associate the z-uno in another device, how i control the received value command?
Re: Associate Z-UNO with another device
When you associate another device with Z-Uno, a setter will be called on each command received.
donic46
Post by donic46 »
Sorry don't understand.
If i have multiple channels in the z-uno, for what channel the setter is called?
For example, i have 2 switches, 4 multilevel sensors in the z-uno, and the z-uno is associate a external z-wave switch, i want when the external switch change value, one of my switch change equal. How i do that?
The setter is called for the channel the packet comes to.
For example if non-channeled command is received, it will be sent to the first channel of that type (see Z-Uno channels mapping explanation on Z-Uno web site). If a MultiChannel encapsulated command is received, the approrpiate setter will be called.
donic46
Post by donic46 »
I was doing with a binary switch trying to associate to a multilevel switch, now I switched to a dimmer and it already working :D
Thanks.
