a question @ petergebruers:
"Note: users of eg Z-Way can find background noise in "Expert User Interface". "
within which menu? where?
Zwave range and power
Re: Zwave range and power
No, Z-Uno do not report RSSI, but Z-Way can help you
In "Z-Wave Expert User Interface", menu "Analytics", item "Background Noise"tomshuette wrote: ↑12 Mar 2019 17:38"Note: users of eg Z-Way can find background noise in "Expert User Interface". "
For more information, see chapter "8 Troubleshoot the Z-Wave Network" in the Z-Way manual, it explains the advanced functions like Zniffer and status views.
Thanks! Understood!
Meet me here: https://forum.fibaro.com/index.php?/pro ... rgebruers/ or here: memberlist.php?mode=viewprofile&u=564463
thanks,
my system will not suport analytics
Are you in the expert menu?
Do you run a recent RaZberry (or UZB) firmware?
no, I use WD my Cloud... the last Firmware release was 2017...
You can download a newer from our site. WD are too slow to approve them within the same year
I have a similar issue. I have a range of about 10-15m, though it drops to around 1m through walls. I have tried powering from both USB and using a power supply, getting the same result each time.
Z-Uno (AU/NZ/BR frequency) - powered by either 12V stepped down from 24V or USB direct (12V disconnected).
I have tested the Z-wave connectivity using two PCs (one a home-built, the other a Surface 3) using HS3 running on Windows and an Aeon ZStick Gen5, on a 1m USB extension cable and also plugged in directly.
The Z-Uno is located inside a waterproof enclosure. It is connected to a display, two relays, and a water level sensor and is reporting all the variables and controlling the relays as required. When I am close enough I receive the tank level result and can send relay on/off commands. However, when I am more than a few metres away I get no connectivity at all.
It appears to be purely range-related, as if the Z-uno is putting out a very weak signal.
Are you sure you bought the ANZ hardware? You can post a photo of the RF side, we will help to recognize not.
When have you bought it?
Purchased February 2018 from zwave.com.au
See attached pictures of the top and bottom of the unit.
- ZUno_Bottom.jpg (384.65 KiB) Viewed 6603 times
- ZUno_Top.jpg (294.92 KiB) Viewed 6603 times
