Battery Power and UART0
DerLexus
Post by DerLexus » 27 Oct 2018 22:00
If i power using a 3,3v battery the Serial0 prints only garbadge. If i using USB Power the same Sketch works perfectly and i see the UART0 output. Do this have todo with the 3.3v power?
Bye
Nino
Re: Battery Power and UART0
Post by PoltoS » 28 Oct 2018 00:12
This might be related with the know hardware issue if Z-Wave chips - it changes MCU speed when connected to USB cable. Try a cable without data wires.
DerLexus
Post by DerLexus » 28 Oct 2018 00:20
Thanks for your reply.
You mean i should try a power only usb cable? But if i use usb everything is fine... problem starts if i use a battery and no usb at all.
Post by PoltoS » 28 Oct 2018 00:23
Make sure the UART speed matches
