zunoSendReport in the Setup routine
Posted: 13 Mar 2019 18:33
I want in my sketch to revert the relays defined in channel 1 to 3 to the default state after a restart event. I do it like this:
is this allowed? does it have any side effects? will the Z-Wave stack be fully initialized before running code from the setup() routine?
thanks
void setup() {
relais1_state = 0;
relais2_state = 0;
relais3_state = 0;
zunoSendReport (1);
zunoSendReport (2);
zunoSendReport (3);
void loop() {
byte relais1_getter() {
if (relais1_state) {
return ZUNO_SWITCHED_ON;
} else {
return ZUNO_SWITCHED_OFF;
byte relais2_getter() {
if (relais2_state ) {
} else {
byte relais3_getter() {
if (relais3_state ) {
} else {
}thanks
