getter() called twice
perjar
Post by perjar »
Dear Forum,
Is it normal that the getter function is called twice everytime, or am I doing something wrong?
My application is a power meter which sends readings to the controller every 2 minutes.
When it is time to send a new report, the sketch prints line 1 below and then calls the zunoSendReport() function.
In the getter() function, I have another print statement which prints line 2. But as you can see, the getter function is called twice, leading to line 3 being printed a few milliseconds later.
1: 22:44:47.032 -> Sending power report. Power : 128
2: 22:44:47.032 -> Getter - Power - Reported value = 128
3: 22:44:47.063 -> Getter - Power - Reported value = 128
Is this as it should? If not, what am I dong wrong?
If yes, why?
Re: getter() called twice
This is certainly because there is also a report from channel 0 (mapped to the channel 1). So this is ok.
2.1.5 will not create channels if it is not needed - this should help to remove duplicates. But in case of many channels of the same time this will still happen on channel #1, since it is mapped to channel 0.
You can test 2.1.5 and read more about channels mapping in this new version
https://forum.z-wave.me/viewtopic.php?f ... 65&p=83074
perjar
Post by perjar »
I can confirm that in 2.1.5 there is only one call to the getter() function which reduces the number of messages by 50% from this device. A very welcome change!
