Hello together,
I have a problem with the z-uno module. I have connected the USB_DP, USB_DM and GND to a USB cable. The VCC andGND is connected to a 3.3V power supply (as depiced in the reference). Pin 13 is wired to a LED (including a fitting resistor). With this setup i can reach the module via USB.I can program it and I can my serial outputs via USB. The LED is flashing also. Everthing fine. But as soon as I disconnect the USB cable from my pc the scatch stops e.g the LED stops flashing, and it remains either on or off. When I plug in the USB cable again, the LED continous flashing. So what have I done wrong? Do I need any pull up/down resistors on the USB pins? For me it looks like the device ist trapped in a USB-ISR. Has anyone an idea? Or would it be possible to post a reference design?
Thank you for your answers
z-uno module stops working when USB is not connected
Re: z-uno module stops working when USB is not connected
Ok I have a few more information about my problem:
1) the z-uno module is really alive and just trappen in something. I implemented a counteron the serial port and it just stops counting when I plug of the USB cable and continous counting when the cable ispluged in again.
2) WhenI plug off the USB calbe the D+ is HIGH and the D- is low which compiles with a USB-Highspeed deviec.
3) The 22Ohm inline resistors on D+/- and the 10kOhm pullup resistor on D+ are ok.
4) I also tried the same sketch on an normal z-uno and it woks fine. On the Module it doesn't work even with the new released toolkit 2.1.5
5) If I pull the D+ down to GND with an 10kOhm or if I pull D- up to 3,3V with a 10kOhm the sketch continous working.
Can anybody comment on these findings? Is my chip broken?
Thank you
Thank you
The same problem observed. When USB_DM is pulled up to +3.3V (after the programming!) by 10kOhm resistor the sketch works properly.
That is what I did as well now. Do you have anSUB connector on your module? Or just headers? I have the suspicion that the chip does something strange. You can observe the identical behaviour if just plugin an USB cabe an a Z-Uno board put some osziprobeson thr D+ and D- pin. Strang
Did you ever work this out? I'm seeing the same behaviour.
I saw in the release notes for 2.1.6 they said:
"Allow disable USB using Serial.end(). Before that non-connected USB was leading to Z-Uno Module hangs."
I tested out just calling Serial.end() and it looks like it's fixed the kind of issues that I was seeing before. This was without even running Serial.begin();
