2.1.5 failed to load sketch of shield configurator
Posted: 23 Aug 2019 08:48
tried to load following sketch of shield configurator and got below response "Can't upload sketch! Something went wrong. Bad response."
Tried different sketches without DS18B20. Works fine. But as soon I add DS18B20 error occurs.
Funny: Sketch with DS18B20 only is fine.
Any ideas?
Thx
MiWa
#include "ZUNO_DS18B20.h"
// Global variables
OneWire ow(11);
DS18B20Sensor ds18b20(&ow);
byte addresses[8 * 1 + 8]; // last one for search
byte number_of_sensors; // Number of sensors found (if less than 1 connected)
signed int temperature[1];
byte pin12SensorBinaryState;
// Z-Wave channels
ZUNO_SETUP_CHANNELS(
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_ONE_DECIMAL, pin11SensorDS18B20Getter_1),
ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_GENERAL_PURPOSE, pin12SensorBinaryGetter)
void setup() {
number_of_sensors = ds18b20.findAllSensors(addresses);
pinMode(12, INPUT_PULLUP);
pin12SensorBinaryState = !digitalRead(12);
void loop() {
if (number_of_sensors >= 1) {
temperature[0] = ds18b20.getTempC100(&addresses[8 * 0])/10;
zunoSendReport(1 + 0);
byte _pin12SensorBinaryState = digitalRead(12);
if (pin12SensorBinaryState != _pin12SensorBinaryState) {
pin12SensorBinaryState = _pin12SensorBinaryState;
zunoSendReport(2);
delay(20);
// Getters and setters
word pin11SensorDS18B20Getter_1() {
return temperature[0];
byte pin12SensorBinaryGetter() {
return pin12SensorBinaryState;
C:\Users\walbe\AppData\Local\Temp\arduino_build_416001/sketch_digital_output.ino
--- USING a list of libraries from:
C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\hardware\zw8051\2.1.5\libraries
C:\Users\walbe\Documents\Arduino\libraries
*** Collecting prototypes...
Preprocessing file: Custom.c with SDCPP...
Preprocessing file: ZUNO_OneWire.cpp with SDCPP...
Compiling ZUNO_OneWire_sdcpp_.cpp ...
Preprocessing file: ZUNO_DS18B20.cpp with SDCPP...
Compiling ZUNO_DS18B20_sdcpp_.cpp ...
Preprocessing file: EEPROM.cpp with SDCPP...
Compiling EEPROM_sdcpp_.cpp ...
Preprocessing file: sketch_digital_output.cpp with SDCPP...
Compiling sketch_digital_output_sdcpp_.cpp ...
Preprocessing file: ZWSupport.cpp with SDCPP...
Compiling ZWSupport_sdcpp_.cpp ...
Compiling ZWSupport_sdcpp_.cpp ...Compiling file "LLCore_arduino.c" by means of SDCC...
sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include" "LLCore_arduino.c"
sdcc: Generating code...
sdcc: Calling assembler...
sdcc: sdas8051.exe -plosgffw "LLCore_arduino.rel" "LLCore_arduino".asm
strncpyz prevented buffer overrun!
Compiling file "Print_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include" "Print_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Print_ucxx.rel" "Print_ucxx".asm
Compiling file "Stream_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include" "Stream_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Stream_ucxx.rel" "Stream_ucxx".asm
Compiling file "HardwareSerial_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include" "HardwareSerial_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HardwareSerial_ucxx.rel" "HardwareSerial_ucxx".asm
Compiling file "HLCore_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include" "HLCore_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HLCore_ucxx.rel" "HLCore_ucxx".asm
HLCore_ucxx.c:612: warning 85: in function delayLoops unreferenced function argument : 'v'
Compiling file "ZUNO_OneWire_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include" "ZUNO_OneWire_ucxx.c"
sdcc: sdas8051.exe -plosgffw "ZUNO_OneWire_ucxx.rel" "ZUNO_OneWire_ucxx".asm
ZUNO_OneWire_ucxx.c
warning 85: in function __cxx__OneWire__method__crc8_02p0505 unreferenced function argument : 'v__this'
Compiling file "ZUNO_DS18B20_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include" "ZUNO_DS18B20_ucxx.c"
sdcc: sdas8051.exe -plosgffw "ZUNO_DS18B20_ucxx.rel" "ZUNO_DS18B20_ucxx".asm
Compiling file "EEPROM_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include" "EEPROM_ucxx.c"
sdcc: sdas8051.exe -plosgffw "EEPROM_ucxx.rel" "EEPROM_ucxx".asm
Compiling file "sketch_digital_output_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include" "sketch_digital_output_ucxx.c"
sdcc: sdas8051.exe -plosgffw "sketch_digital_output_ucxx.rel" "sketch_digital_output_ucxx".asm
Compiling file "ZWSupport_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include" "ZWSupport_ucxx.c"
sdcc: sdas8051.exe -plosgffw "ZWSupport_ucxx.rel" "ZWSupport_ucxx".asm
ZWSupport_ucxx.c
warning 85: in function zunoCallback unreferenced local variable : 'i'
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\walbe\Documents\ArduinoData\packages\Z-Uno\tools\zuno_toolchain\00.08.80/zuno_toolchain/sdcc/\bin\..\include" "main.c"
sdcc: sdas8051.exe -plosgffw "main.rel" "main".asm
sdcc: Calling linker...
sdcc: sdld.exe -nf "main.lk"
Making firmware file: C:\Users\walbe\AppData\Local\Temp\arduino_build_416001/sketch_digital_output.ino-0215.hex ...packihx: read 244 lines, wrote 460: OK.
Fixing ISR table in C:\Users\walbe\AppData\Local\Temp\arduino_build_416001/sketch_digital_output.ino-0215.hex ...
Making binary firmware file C:\Users\walbe\AppData\Local\Temp\arduino_build_416001/sketch_digital_output.ino-0215.bin. Use it in Z-Way for wireless update procedure.[Done]
Elapsed:18.9049999714 s
Der Sketch verwendet 7150 Bytes (22%) des Programmspeicherplatzes. Das Maximum sind 32256 Bytes.
Globale Variablen verwenden 225 Bytes des dynamischen Speichers.
Openning port ..............................
Openning port .............................. OK
Stoping the user code ..............................
Stoping the user code .............................. OK
Closing port ..............................
Closing port .............................. OK
RAW Info:
AA AA BB BB 01 15 01 10
00 01 02 0F 66 C2 26 CC
02 7F C6 62 83 7F FF 7F
FC 01 15 02 0F 4C A3 02
00 16 12 4C 08 3E 8A AF
F8 A7 1A 2A 20 2C 26 3F
2F E1 0F 53 40 C3 97 2C
2E B6 EE 0F 23 72 7C 9B
14 D0 41 0C 12 06 B9 02
AA 10 E3 04 01 1E
FIRMWARE DATA
REVISION:02.15
Z-WAVE FREQUENCY:EU
ORIGINAL FW. CRC32: 66 C2 26 CC
MAXIMUM CODE SIZE: 30 KB
CURRENT FW. CRC16: 4C A3
RADIO CHANNELS: 02
HARDWARE DATA
CALIBRATION
MAIN:00 TX: 16 12
DEVICE PUBLIC KEY:
HEX: 31 31 FB A3 9D B2 3C 6C 9A 7F C8 1F F7 98 17 A0 65 CA 25 4A 87 A6 39 2C 11 2C 3D 16 01 BF 11 41
DEC: 12593-64419-40370-15468-39551-51231-63384-06048-26058-09546-34726-14636-04396-15638-00447-04417
PRODUCTION DATA
YOUR ZUNO S/N: 0C 12 06 B9 02 AA 10 04 01
PRODUCTION TIME:
WEEK:12 YEAR:2018
WORKSTATION:
NUMBER:16 SEQUENCE:682
HARDWARE:
CHIP:1721 REVISION:1025
Writing NVM data [> ] (0%)
Writing NVM data [> ] (1%)
Writing NVM data [=> ] (2%)
Writing NVM data [=> ] (3%)
Writing NVM data [==> ] (4%)
Writing NVM data [==> ] (5%)
Writing NVM data [===> ] (6%)
Writing NVM data [===> ] (7%)
Writing NVM data [====> ] (8%)
Writing NVM data [====> ] (9%)
Writing NVM data [=====> ] (10%)
Writing NVM data [=====> ] (11%)
Writing NVM data [======> ] (12%)
Writing NVM data [======> ] (13%)
Writing NVM data [=======> ] (14%)
Writing NVM data [=======> ] (15%)
Writing NVM data [========> ] (16%)
Writing NVM data [========> ] (17%)
Writing NVM data [=========> ] (18%)
Writing NVM data [=========> ] (19%)
Writing NVM data [==========> ] (20%)
Writing NVM data [==========> ] (21%)
Writing NVM data [===========> ] (22%)
Writing NVM data [===========> ] (23%)
Writing NVM data [============> ] (24%)
Writing NVM data [============> ] (25%)
Writing NVM data [=============> ] (26%)
Writing NVM data [=============> ] (27%)
Writing NVM data [==============> ] (28%)
Writing NVM data [==============> ] (29%)
Writing NVM data [===============> ] (30%)
Writing NVM data [===============> ] (31%)
Writing NVM data [================> ] (32%)
Writing NVM data [================> ] (33%)
Writing NVM data [=================> ] (34%)
Writing NVM data [=================> ] (35%)
Writing NVM data [==================> ] (36%)
Writing NVM data [==================> ] (37%)
Writing NVM data [===================> ] (38%)
Writing NVM data [===================> ] (39%)
Writing NVM data [====================> ] (40%)
Writing NVM data [====================> ] (41%)
Writing NVM data [=====================> ] (42%)
Writing NVM data [=====================> ] (43%)
Writing NVM data [======================> ] (44%)
Writing NVM data [======================> ] (45%)
Writing NVM data [=======================> ] (46%)
Writing NVM data [=======================> ] (47%)
Writing NVM data [========================> ] (48%)
Writing NVM data [========================> ] (49%)
Writing NVM data [=========================> ] (50%)
Writing NVM data [=========================> ] (51%)
Writing NVM data [==========================> ] (52%)
Writing NVM data [==========================> ] (53%)
Writing NVM data [===========================> ] (54%)
Writing NVM data [===========================> ] (55%)
Writing NVM data [============================> ] (56%)
Writing NVM data [============================> ] (57%)
Writing NVM data [=============================> ] (58%)
Writing NVM data [=============================> ] (59%)
Writing NVM data [==============================> ] (60%)
Writing NVM data [==============================> ] (61%)
Writing NVM data [===============================> ] (62%)
Writing NVM data [===============================> ] (63%)
Writing NVM data [================================> ] (64%)
Writing NVM data [================================> ] (65%)
Writing NVM data [=================================> ] (66%)
Writing NVM data [=================================> ] (67%)
Writing NVM data [==================================> ] (68%)
Writing NVM data [==================================> ] (69%)
Writing NVM data [===================================> ] (70%)
Writing NVM data [===================================> ] (71%)
Writing NVM data [====================================> ] (72%)
Writing NVM data [====================================> ] (73%)
Writing NVM data [=====================================> ] (74%)
Writing NVM data [=====================================> ] (75%)
Writing NVM data [======================================> ] (76%)
Writing NVM data [======================================> ] (77%)
Writing NVM data [=======================================> ] (78%)
Writing NVM data [=======================================> ] (79%)
Writing NVM data [========================================> ] (80%)
Writing NVM data [========================================> ] (81%)
Writing NVM data [=========================================> ] (82%)
Writing NVM data [=========================================> ] (83%)
Writing NVM data [==========================================> ] (84%)
Writing NVM data [==========================================> ] (85%)
Writing NVM data [===========================================> ] (86%)
Writing NVM data [===========================================> ] (87%)
Writing NVM data [============================================> ] (88%)
Writing NVM data [============================================> ] (89%)
Writing NVM data [=============================================> ] (90%)
Writing NVM data [=============================================> ] (91%)
Writing NVM data [==============================================> ] (92%)
Writing NVM data [==============================================> ] (93%)
Writing NVM data [===============================================> ] (94%)
Writing NVM data [===============================================> ] (95%)
Writing NVM data [================================================> ] (96%)
Writing NVM data [================================================> ] (97%)
Writing NVM data [=================================================>] (98%)
Writing NVM data [=================================================>] (99%)
Writing NVM data .............................. OK
Sketch crc16:7fe1 size:1c1e (7.03 kB)
Pushing sketch ..............................NEEDED:2 GET:0
Error 0 Can't upload sketch! Something went wrong. Bad response.
NEEDED:1 GET:0
NEEDED:1 GET:0
NEEDED:1 GET:0
NEEDED:1 GET:0
NEEDED:1 GET:0
NEEDED:1 GET:0
Reseting chip ..............................
Reseting chip .............................. OK
ELAPSED:16.2039999962s
Any ideas?
Thx
MiWa
// Global variables
OneWire ow(11);
// Z-Wave channels
void setup() {
void loop() {
zunoSendReport(2);
delay(20);
ZUNO_OneWire_ucxx.c
ZWSupport_ucxx.c
RAW Info:
AA 10 E3 04 01 1E
FIRMWARE DATA
REVISION:02.15
Z-WAVE FREQUENCY:EU
RADIO CHANNELS: 02
HARDWARE DATA
CALIBRATION
MAIN:00 TX: 16 12
DEVICE PUBLIC KEY:
PRODUCTION DATA
PRODUCTION TIME:
WEEK:12 YEAR:2018
WORKSTATION:
HARDWARE:
NEEDED:1 GET:0
NEEDED:1 GET:0
NEEDED:1 GET:0
NEEDED:1 GET:0
NEEDED:1 GET:0
NEEDED:1 GET:0
