Z-Uno and FHEM
javatd
Z-Uno and FHEM
Post by javatd »
Hi. I'm trying to get the Z-Uno working properly with my home automation software FHEM. I'm struggeling with different things and hope that you can help me.
One of my simpler problems (I think): the unsolicited messages are not sent. If I got the handbook of the Z-Uno right, the getter is called in case of firing
zunoSendReport
. My code in the getter is as follows:
word getterTemperature() {
   Serial.println("Called: getterTemperature");
  return temperature;
When polling the temperature from FHEM the output is shown on the serial interface. In case of the unsolicited message triggered by
zunoSendReport(channel)
there is no output on the console. The channel is initialized as follows
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE,
                          SENSOR_MULTILEVEL_SCALE_CELSIUS,
                          SENSOR_MULTILEVEL_SIZE_TWO_BYTES,
                          SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS,
                          getterTemperature)
The
zunoSendReport
is triggered each 5 minutes. So what I'm doing wrong?
javatd
Re: Z-Uno and FHEM
Post by javatd »
Seems that I have to answer it myself. The problem is, I've found a solution but have no explaination for it (so if anyone knows please share your knowledge!).
Once I changed the settings from
Erase NVM: All
to
Erase NVM: Disabled
it works like expected. The unsolicited message triggered by
zunoSendReport()
calles the getter and the message is printed to the console.
Re: Z-Uno and FHEM
The Erase is for cleaning things in Z-Uno. And it is cleaning association of the Z-Uno to the controller (FHEM), so if you include the device it works, but no reports are sent anymore after next sketch upload.
javatd
Re: Z-Uno and FHEM
Post by javatd »
I've tested this. In case of
Erase NVM: All
it doesn't work properly even if excluded and than re-included into the controller.
Re: Z-Uno and FHEM
Should. This parameter is to erase full memory of Z-Uno prior to sketch upload. But during inclustion the controller should set everything up gain.
