DS18B20 to Z-Uno per diagram ?????????
Posted: 12 Jan 2020 22:35
by poordom
Good afternoon All,
Since my Z-Uno has been recognized by Vera, I've started with the addition of sensors, but then, I really got confused.
The DS18B20 hook up to the Z-Uno, didn't make sense to me, so I hope someone can explain the setup to me.
From what I understand, one should not connect 5 volts to input, yet the diagram shows powering up the sensor via the 5V output from the Z-Uno, the data output from the DS18B20 is connected to either pins 9, 10 or 11, instead of the AD inputs like 3,4,5or 6, why?
Thanks Guys
Dom
Re: DS18B20 to Z-Uno per diagram ?????????
Posted: 13 Jan 2020 19:32
The data pin should be connected to pin 11,OW. This is correct. But the power should be 5V since the sensor requires 5 volts
Posted: 13 Jan 2020 20:53
by poordom
Good morning PoltoS,
Am I keeping you busy.
OK, in response to your answer, will using the 5v obtained form the Z-Uno card affect anything, if not I could use a TMP36 and a TMP35. When is it NOT recommended to power Sensors with 5 Volt, in order to avoid damaging Z-Uno.
Thank you so much PoltoS, I really appreciate your assistance.
Dom
Posted: 14 Jan 2020 01:57
DS18B20 gives very small current and can not damage Z-Uno. It works perfectly with the Shield and with Z-Uno. We hae tested up to 32 of them
Posted: 14 Jan 2020 15:09
by michap
sorry, just to be safe I would not use 5V for the 18B20 with Z-Uno.
The logic signal will be >3.3V on the output of the 18B20 what is not recommended for the Z-Uno chip (I have tested it on several sensors).
@Poltos - you are really sure that it is safe for the chip? Would be good to know.
And - the sensor does not require 5V - it is working from 3.0 ... 5.5V.
https://datasheets.maximintegrated.com/ ... S18B20.pdf
So I would try to use the 3.3V output, or work with a logic level converter for the data pin if using 5V.
Michael
Posted: 14 Jan 2020 21:18
Well, we even have official examples in our web site.
This is data pin with very low current, so looks to be safe
