How to use multichannel ?
Jdouc
Post by Jdouc »
Hi everyone,
I’ve spent 2 days in trying to get the zwave multichannel working.
The zuno is attached to an eedomus box. From my understanding, the zwave layer in the zuno is somehow “optimizing” the multichannel configuration, so that the same types of channels are somehow grouped into one channel.
I tried a lot of multichannel inclusion commands with the eedomus, this is for now unsuccessful.
I cannot exclude that the controller itself is not messing the attachment, but the eedomus is intended to manage the zuno with multichannel zwave.
The thing is, my project is to control a Fujitsu a/c, so I definitely need the multichannel feature: on/off, target temperature, room temperature, mode...
Has anyone succeeded in attaching a zuno to an eedomus with multichannel?
Thanks for your support :-)
Re: How to use multichannel ?
If eedomus is based on OpenZWave, you should make a template for OpenZWave
C.Scavardo
Post by C.Scavardo »
Hi, I just started playing with Z-Uno, and eedomus.
I can connect 2 leds on the Z-Uno, and turn them ON or OFF.
The LED status is correctly updated in the eedomus.
I used:
ZUNO_SETUP_CHANNELS(
  ZUNO_SWITCH_BINARY(getterLed1, setterLed1),
  ZUNO_SWITCH_BINARY(getterLed2, setterLed2)
Then; I connected a button, INPUT_PULLUP mode:
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_DOOR_WINDOW,getterButon)
That button was correctly handled in eedomus.
So, I added another one button:
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_DOOR_WINDOW,getterButon1),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_DOOR_WINDOW,getterButon2)
And, the behaviour looks broken, from eedomus point of view.
The values are correctly updated in the serial monitor, but, the eedomus does not reflect them.
The eedomus will update the values when it will do the polling, reduced to 30 seconds in that case.
But, looks like the zunoSendReport(pin) does nothing, from the eedomus.
I can notive that getters are corrects, values are corrects... but, eedomus values are incorrects... why... still investigating !
Make sure to set up a multichannel association group #1 with 1:0
C.Scavardo
Hi PoltoS,
Is there a doc to "set up a multi channel association group #1 with 1:0" ?
Z-Uno is new for me, I don't understand.
Thank you.
You need to open Association tab in your Z-Wave controller and set multichannel association in group 1 of Z-Uno to 1:0
C.Scavardo
Thank you PoltoS, I'll try soon ;-)
