Servo keeps moving
Posted: 28 Mar 2020 10:43
All,
Hopefully you can get me out of the following issue. At the moment I want to control a servo (Furaba S3003) and I am able to control it. But when it has arrived its position, it keeps moving every second for around 10 degrees. I am using an external power source.
This is what I tried:
Thanks in advance!
- All possible PINS (9 - 16)
- Controlling the servo via an Arduino (which works)
#include <ZUNO_SERVO.h>
#define SERVO 12
ZUNO_SETUP_CHANNELS(ZUNO_BLINDS(getData, setData));
ZUNO_SETUP_DEBUG_MODE(DEBUG_ON);
ServoController servo(SERVO);
int positionDegrees;
int positionPercentage;
void setup() {
servo.begin();
Serial.begin(115200);
doServo(90);
void loop() {
// Managed by ZUno.
byte getData() {
return positionPercentage;
void setData(byte data) {
Serial.print("Percentage: ");
Serial.println(data);
positionPercentage = data;
int value = map(data, 0, 99, 15, 165);
doServo(value);
void doServo(int pos) {
setServo(pos);
void setServo(int value) {
Serial.print("Degrees: ");
Serial.println(value);
Serial.println("- - -");
servo.setValue(value);
positionDegrees = value;
