BTN is not working
thisguy
BTN is not working
Post by thisguy »
Hi all,
So I have tried a lot of different things, even bought a razberry just because I thought my uno was not compatible with my current controller.
It appears that the button does not work, the reset one does but the BTN does not. loading a simple sketch that would log the button being pressed shows nothing.
This also makes it impossible to include the device in anything.
It never worked and I believe my device might be faulty, can someone please verify?
#define BTN_PIN     18
byte lastButtonState;
void setup() {
  Serial.begin(115200);
  pinMode(BTN_PIN, INPUT_PULLUP); // set button pin as input
void loop() {
  byte currenButtonState = digitalRead(BTN_PIN);
  Serial.println("");
      if (currenButtonState == LOW) { // if button is pressed
      Serial.print("LOW");
    } else {                        // if button is released
      Serial.print("HIGH");
  delay(100);
thisguy
Re: BTN is not working
Post by thisguy »
Ok, so terminating both ends of the button with a male <-> male cord triggers a LOW so the button is actually broken, that sucks. guess return to store
Unfortunatelly this happened few times due to the aggressive flux. Please swap it in the shop.
