Need some help about Z-Uno
Gbajolet
Post by Gbajolet »
Dear All,
I have a project with tank and temperature level and also letter water meter and fountain flow adjustment. Now I am testing step by step ans I am using the program as example or project. My domotc box is EEdomus from connected object and the Z-Uno is referenced as compatible.
But: I tested the program with several temperature sensors (2 for me) and it is OK
I also tested the HC-SR04 program call: "Pellet bunker temperature and fulfillment level " and it is OK too
I joinned both programs and I recheck several time line per line, the hardware side was alredy rechecked and I didn't find my problem.
When I add some serial print command, everything seems OK but with the BOX, the temperature 1 and 2 are ok but the volume no. I spent hours to find my mistake without success. Could you help?
I join the code
Thank you by advance
Gilles
// 2 temperature sensors DS18B20, 1 ultrasonic distance sensor HC-SR04
#include "ZUNO_DS18B20.h"
#define DS18B20_BUS_PIN 11                  // Pin to which DS18B20 bus is connected
#define N_SENSOR 2                          // Number of DS18B20 sensors
OneWire ow(DS18B20_BUS_PIN);
DS18B20Sensor ds18b20(&ow);
#define ADDR_SIZE 8                         // Size of address of devices on 1-wire bus
byte addresses[ADDR_SIZE * N_SENSOR];       // Here we store all the scanned addresses
#define ADDR(i) (&addresses[i * ADDR_SIZE]) // Macro to simplify our life
byte number_of_sensors;                     // Number of sensors found
word temperature[N_SENSOR];                 // Here we store temperatures
// Define Z-Wave channels. Add more if you need more sensors
ZUNO_SETUP_CHANNELS(
        ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp1),
        ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp2),
  //ultrasonic sensor
        ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_GENERAL_PURPOSE_VALUE,4,SENSOR_MULTILEVEL_SIZE_TWO_BYTES,0,getterVol)
ZUNO_SETUP_ASSOCIATIONS(ZUNO_ASSOCIATION_GROUP_SET_VALUE); // to control other devices
int readPin = 9;
int triggerPin = 10;
byte controlState = 0;
dword distance;
dword hauteur_eau;
dword distance_capteur;
dword distance_max;
dword volume;
void setup() {
  Serial.begin();
  number_of_sensors = ds18b20.findAllSensors(addresses);
  pinMode(readPin, INPUT);
  pinMode(triggerPin, OUTPUT);
  digitalWrite(triggerPin, LOW);
  distance_capteur=30;
  distance_max=230;
void loop() {
   int tmp;
  // trigger measurement
  delayMicroseconds(10);
  digitalWrite(triggerPin, HIGH);
  // read pulse width
  tmp = pulseIn(readPin, HIGH, 100000);
Serial.println("tmp");
Serial.println(tmp);
    distance = tmp / 58; // convert to cm, see datasheet
    Serial.println(distance);
 hauteur_eau =(distance_max-distance);
  Serial.println(hauteur_eau);
  volume = (hauteur_eau *45);
   Serial.println(volume);
   Serial.println(temperature[0]);
   Serial.println(temperature[1]);
  for (byte i = 0; i < number_of_sensors; i++) {
    // Read temperature
    // It already encoded for format VVV.vv and doesn't use float
    temperature[i] = ds18b20.getTempC100(ADDR(i));
  // Report all the sensors at the end of the loop
  for(byte i = 0; i < 5; i++){
    zunoSendReport(i+1);
  delay(1000);
// Getters. Add more if you need more sensors
word getterTemp1() {
  return temperature[0];
word getterTemp2() {
  return temperature[1];
dword getterVol() {
  return volume;
Gbajolet
Re: Need some help about Z-Uno
Post by Gbajolet »
Additionnal information :"When I add some serial print command, everything seems OK" it is wrong , the "tmp" isn't measured.
Gilles
michap
Post by michap »
the first I see is that you have 3 sensors (2x temp + 1x level)
but you use:
should be
  for(byte i = 0; i < 3; i++){
why the level (tmp) will not be printed out, do not see in this time - it is really working without temperature part?
Michael
Gbajolet
Post by Gbajolet »
Hello, thank you for your help.
Finally I found the problem: I add one temperature sensor: 3 + 1 distance sensor and after integration on the Box I had 4 widgets : 2 temp and 1 volume and 1 for nothing, I hide the last one and everything is ok, it seems that the problem is coming from the box
Gilles
