installation error: "zuno_toolchain is not available for your OS"
norbert
Post by norbert »
Hi there,
I just got the new Z-Uno and followed the instruction under https://z-uno.z-wave.me/install to set up the Arduino IDE (latest v1.8.13).
But I failed in step 5 : "Go to Tools → Board → Boards manager. Scroll down, you should see a package "Z-Uno by Z-WAVE>ME". Install it"
When I click on install button I get the following error:
"Werkzeug zuno_toolchain ist für Ihr Betriebssysten nicht verfügbar", in english something like: "Tool zuno_toolchain is not available for your OS".
The full output in the IDE window is this:
Werkzeug zuno_toolchain ist für Ihr Betriebssystem nicht verfügbar.
java.lang.RuntimeException: java.lang.Exception: Werkzeug zuno_toolchain ist für Ihr Betriebssystem nicht verfügbar.
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$2(ContributionManagerUI.java:175)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.Exception: Werkzeug zuno_toolchain ist für Ihr Betriebssystem nicht verfügbar.
at cc.arduino.contributions.packages.ContributionInstaller.install(ContributionInstaller.java:89)
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$2(ContributionManagerUI.java:172)
... 1 more
I am using Windows 10 (1909) 64-bit OS.
I have reinstalled Java (version 8 update 251), because it appears, that java code is executed here.
Also done everything a administrator.
I searched the forum for this message, but did not find anything helpful.
Is there anyone out there, who can tell what I am doing wrong or what is missing on my PC?
Thanks a lot!
Norbert
Re: installation error: "zuno_toolchain is not available for your OS"
Please use Arduino IDE 1.8.12. The new 1.8.13 will be supported soon
norbert
Post by norbert »
Thank you very much for the quick reply. IDE 1.8.12 did the job and I can retrieve Board Information!
We have just release 2.1.6 - should now work with 1.8.13 too
https://forum.z-wave.me/viewtopic.php?f=3427&t=33761
norbert
Post by norbert »
Just installed it. Works!
