Where to connect water meters outputs to z-uno shield
jadlr
Post by jadlr »
Hi
I bought a z-uno shield and i want to use it as a water meter. I upload the water meter example
https://z-uno.z-wave.me/examples/Water-Meter/
But i don't know where i should connect the two cables from each data meter (dry contacts output) to the z-uno shield.
Should be on an analog input but ....
I tried the configurator but there are several options and i don't have a clue where i should do the connections.
https://z-uno.z-wave.me/shield/configur ... C&pin12=NC
Please advice
Thank you
Re: Where to connect water meters outputs to z-uno shield
As stated in the very beginning of the code, it is pin 0/1:
#define PIN_COLD 0
#define PIN_HOT 1
You can change them to any other pin in the code. Those are Z-Uno pins, so for the shield change then to other pins like A1-A4 or 8-12 as pins 0/1 are not connected on Z-Uno bornes.
jadlr
Post by jadlr »
Thank you
Using the ink bellow i cannot find the pins you suggest
Is there any picture that i can use in order to do the right connections?
As mentioned above, those pins are not connected to the Shield, so you are suggested to change them to 8-12
jadlr
Post by jadlr »
Thank you
You know where are the pins 8,9,10,11,12 on the z-uno shield?
Is there any picture with that information?
Regards
