Hi everyone,
i can't figure out how to get decimals on the temperature and humidity readings from the DHT22 sensor.
Can anyone help me please?
Thank you!
DHT22 sensor with decimals
Re: DHT22 sensor with decimals
I think I have solved this, now I do some tests.
// add library
#include "ZUNO_DHT.h"
// pin connection
#define DHTPIN 9 // first sensor
DHT dht(DHTPIN, DHT22);
int temperatura; // here we will store the temperature
int umidita; // here we will store the humidity
// set up channel
ZUNO_SETUP_CHANNELS(
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE,
SENSOR_MULTILEVEL_SCALE_CELSIUS,
SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS,
getterTemp),
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_RELATIVE_HUMIDITY,
SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE,
getterUmid)
void setup() {
Serial.begin();
Serial.println("start");
void loop() {
// obtaining readings from the sensor DHT22
float temp = dht.readTemperature();
// make scaled word value for report
temperatura=int(temp*100);
float umid = dht.readHumidity();
umidita=int(umid*100);
// send data to channel
zunoSendReport(1);
zunoSendReport(2);
// send every 20 second
delay(20000);
word getterTemp() {
return temperatura;
word getterUmid() {
return umidita;
