I am new to Z-Uno and Fibaro. I recently purchased a Z-Uno device (Australia) and also a Fibaro Home Center 3 hub. I programmed a simple multi channel sketch to the Z-Uno (firmware 2.1.6) and attempted to add the device to the hub. The hub discovers the device, but claims the device has no template. Downloading the device data I see this:
<manufacturerID>0000</manufacturerID><productType>0000</productType><productID>0000</productID>...
From that I can see on the web the manufacturer ID should be hard coded to 0x0115, and the productType and productID should be 0x0110 and 0x0001. Is my Z-Uno broken? Has anyone else experienced this?
Thank you,
Johan
