I see one for the Z-Uno dev board at the bottom of https://z-uno.z-wave.me/technical/, but does anyone have such a file for the Z-Uno Module?
Thanks!
KiCad file for the Module?
Re: KiCad file for the Module?
There are some EasyEDA prints here but I don't know if they can be ported to KiCad
https://easyeda.com/search?wd=Z-uno&ind ... components
I have a symbol and footprint library for both the ZUno board and module. My memory is hazy, but I'm pretty sure the module symbol and footprint are my own work. The other stuff I may have found somewhere, but it probably had to tweak it.
I've used the module footprint on a single project and it matched the part correctly.
I just put them in a GitHub repo at https://github.com/marcsaegesser/ZUno_Kicad
Hope it helps and if you can make them better then please share.
beamerblvd
AJTozer, do you know if this footprint still works for the Z-Uno 2? Or will it have a different footprint?
samuelkadolph
beamerblvd, I got my hands on a Z-Uno 2 finally and I've used my 1s and the 2 to build an updated KiCAD library. The pins seem to be in the same position so the footprints should be identical.
I've put the library at https://github.com/samuelkadolph/zuno-kicad. You can install it using the new Plugin repository in KiCAD 7. Eventually I'll add a symbol and footprint for the module. I wish I could get my hands on them though. Seem to be unobtainium.
samuelkadolph
I've added the Z-Uno module symbol and footprint and released v0.3.0.
