Display issue with an OLED
fredfit
Post by fredfit »
I'm trying to do a simple display on a 128x64 I2C OLED of the humidity value from a soil moisture sensor like this one:
https://www.smart-prototyping.com/image ... 50x750.jpg
I can well retrieve the humidity value (named "valueHygro" in my sketch) from the sensor module connected to ADC1 (pin 4 of the Z-Uno) but get an issue when displaying it on the OLED (SCL to pin 9, SDA to pin 10) :
- if I leave the sensor outside (no humidity), a 0 is well displayed
- now if I put the sensor into a glass of water, I get 100 displayed
All is well so far, but if I now remove the sensor from the water, it now displays 000 instead of 0. It seems that the 2 last zeros of "100" that were not displayed at step 1 now remains displayed ...
Is there a way to avoid this ?
My sketch:
#include "Wire.h"
#include "ZUNO_OLED_I2C.h"
#include "ZUNO_OLED_FONT_NUMB16.h"
#include "ZUNO_OLED_FONT_RUS8.h"
OLED oled;
#define pinHygro 4 // ADC1
int valueHygro;
void setup() {
  pinMode(pinHygro, INPUT);
  oled.begin();
  oled.clrscr();
void loop() {
  valueHygro = analogRead(pinHygro);
  valueHygro = constrain(valueHygro,400,1023);
  valueHygro = map(valueHygro,400,1023,100,0);
  oled.gotoXY(0,4);
  oled.setFont(zuno_font_numbers16);
  oled.print(valueHygro);
  delay(500);
I would have expected that a command line like "oled.clrline" exist, that I would place just before "oled.print(valueHygro);", but not ...
In my project, I will have other things to display, I try to avoid to do a "oled.clrscr" command at the beginning of the loop.
Thanks !
Re: Display issue with an OLED
You can print old value with background color before printing the new one. Typical trick for small displays
fredfit
Post by fredfit »
Thank you PoltoS for this trick.
Unfortunately, I don't see any available "oled." command that can change the color of the text.
Could you be more precise ?
By the way, I woud also be interested in having a full list of the available commands.
p0lyg0n1
Post by p0lyg0n1 »
1. About OLED:
the simpliest way is method void fillRect(byte w, byte h, byte fill);
oled.gotoXY(needed_x_in_pixels,needed_y_in_pixels/8);
oled.fillRect(needed_x_size_in_pixel, needed_y_size_in_pixels/8, 0);
2. If you have some problems with stack don't use map() function. It's to fat for i8051, because it use 4 32bit values as operands and one for return.
Best regards,
Alex.
fredfit
Post by fredfit »
Thank you p0lyg0n1 !
I will try to use oled.fillRect (I just realized that "Rec" stands for "Rectangle" !), even if I cannot figure out what sizes I should give to x and y when font_numbers16 is being used ... I will give it a try.
I don't have any problem with the map() function for the time being.
