After installing the latest Java JRE results in
C:\Users\Gerald\AppData\Local\Temp\build875019251353671631.tmp/zuno_SimpleDimmer.cpp
Preprocessing file: Custom.c with SDCPP...
Custom_sdcpp_.c:396:12:error:redefinition of 'byte' as different kind of symbol
Print_sdcpp_.cpp:543:17& has lower precedence than ==; == will be evaluated first
uCxx returned error code:1
Error compiling.
Latest Java update causes prerpocessing error
Re: Latest Java update causes prerpocessing error
It may not be Java related, but sdccp simply causes the problem.
I have found the problem. A library called grbl (for 3D printing) caused the problem. It includes Print.h which conflicts with the z-uno board package. Deleting the grbl library from the Arduino IDE solved it.
