I would like to make some changes to an existing zuno project.
In particular I would like to add a few possible associations. Since I will probably be doing a few flash -> test cycles and things may change while I am updating this project I would like to avoid excluding / including the zuno every time I change the number of association groups.
I tried in the past using the debug parameter but was never able to figure this out... Lets say I want to add 1 or 2 new associant groups.
1) Change debug parameter to 1
2) Flash new firmware with new (more) association groups
3) Re-interview in z-way-server
At this point should z-way-server pick up the new possible association groups?
Thanks!
Zuno - Debug mode - How does this actually work?
Re: Zuno - Debug mode - How does this actually work?
I just tried this and z-way-server is not showing the new association groups
This would be pretty useful as the zuno I am updating is behind a wall switch... So I would have to remove it etc... 10 minutes, but still a bit of a pain.
Ok I have somewhat figured it out... I am already at the max number of association groups... 4.
