problems with shield pins
tjansteman
I bought a z-uno shield and encountered a problem with some pins when used as switches. When I use the z-uno in a breadboard the switches work fine but when I put in the shield pin 11 and 12 are always on. Any suggestions about what the fault is ? , i've used the example for four relays on the z-uno page.
Re: problems with shield pins
1) Pin11 is used as OneWire bus pin on the shield. It has pull-up resistor. Seems that's why the relay is always on.
2) Pin12 doesn't have "hardware" pull-up. I don't know why it has logic 1 level in your case.
Which type of relay do you use? Is it a module or original electromechanical relay without any additional components? Shield is able to control high current load only by means of PWM1-PWM4 terminals. Shield is able to control modules with 3v logic on another terminals(module has to meet current requirements of Z-Uno in this case: current on the one pin < 5mA), but you have to set the jumpers right way. Don't use pin11 because of integrated pull-up.
Please use the configurator tool to achieve needed settings of the the SHIELD: https://z-uno.z-wave.me/shield/configurator/.
Best regards,
Alex.
Best regards,
Alex.
