Z-Uno module do not connect to wave network
Posted: 24 Feb 2021 20:45
Hi
I have made a pcb with the Z-Uno module to control my windows roller shade.
This is working fine with the device handler 'zwave window shade' from Smartthings.
My device is battery operated.
Only problem I have, is that I have to reset my Zuno 2 times after disconnecting the battery and connecting it again, before the zuno will connect to the zwave network (Smartthings controller).
This problem is quite annoying, because you have to remember every time you change battery.....
I tried to make a power on reset, that keeps the reset low for 1-2 seconds, to see if that helps, but no, I still have to press my reset button 2 times (1 time is not enough).
Anyone that can help with this problem?
