Z-Uno Full electronic diagram
fredfit
Post by fredfit »
Hi all,
Is there a full electronic diagram of the Z-Uno available somewhere ?
I'm trying to find the value of C13 which is the very small SMD capacitor close to the antenna.
I unfortunately removed it accidentely while desoldering the antenna and I lost it.
Thanks !
Re: Z-Uno Full electronic diagram
12 pF
fredfit
Post by fredfit »
Thank you PoltoS.
Very low value for a capacitor. Is it a coupling capacitor between the antenna and the rest of the RF circuit ?
Can I replace it by just a short circuit ? Because it's very very tiny and it would be hard to solder an new one in place.
It is the antenna matching. If you use another value the matching will be wrong. Better not to use it rather than use 0 Ohm.
fredfit
Post by fredfit »
Ok thanks
Just one last question: do you confirm the SMD size of 0402 ?
Yes
