Here is my code for a watering system that includes:
- a moisture sensor
- a valve
- a water tank with a level sensor
#include "Wire.h"
#define pinValve 19
#define pinMoisture 4 // Moisture sensor on ADC1
#define pinLevel 12 // Water tank sensor (0 when full)
byte valveValue;
byte lastLevelState;
byte currenLevelState;
int valueMoisture;
// Sleep mode
/* Channels definition
- channel 1: valve
- channel 2: moisture
- channel 3: water tank level
ZUNO_SETUP_CHANNELS(
ZUNO_SWITCH_BINARY(getterValve, setterValve),
ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_GENERAL_PURPOSE, getterLevel),
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_MOISTURE, SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE, SENSOR_MULTILEVEL_SIZE_ONE_BYTE, SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS, getterMoisture)
void setup() {
pinMode(pinValve, OUTPUT);
pinMode(pinMoisture, INPUT);
pinMode(pinLevel, INPUT_PULLUP);
void loop() {
// Water level reading
byte currenLevelState = digitalRead(pinLevel);
if (currenLevelState != lastLevelState) {
lastLevelState = currenLevelState;
zunoSendReport(3);
// Moisture reading
valueMoisture = analogRead(pinMoisture);
valueMoisture = constrain(valueMoisture,400,1023);
valueMoisture = map(valueMoisture,400,1023,100,0); //Mapping: 400 means 100%, 1023 means 0%
zunoSendReport(2);
//Valve is opened if moisture <20% and tank is not empty
if (valueMoisture < 20 && currentLevelState == LOW) {
digitalWrite(pinValve,HIGH);
else {
digitalWrite(pinValve,LOW);
void setterValve(byte newvalue){
digitalWrite(pinValve, (newvalue > 0) ? HIGH : LOW);
valveValue = newvalue;
byte getterValve() {
return valveValue;
byte getterLevel() {
if (lastLevelState == 0) { // if low level, send 255, instead send 0
return 255;
} else {
return 0;
word getterMoisture(void) {
return (valueMoisture);
What I would now like from my Jeedom board is to be able to
- monitor when the valve was opened (history). If I add a "zunoSendReport(1);" like this, will it work ? I'm not very comfortable with this command ...
else {
zunoSendReport(1);
//Valve is opened if moisture <20% and tank is not empty, or forced from Jeedom
if ((valueMoisture < 20 && currentLevelState == LOW) || valveValue == HIGH) {
else {
Thanks !
