z-uno communication problem on w7 64 ??
Ric1050
Post by Ric1050 »
Hello
I spent over 10 hours trying to communicate with a <z-uno version 2 rev 6>
-- with battery ??? undocumented -- is it genuine ?
I'm on W7 64
the UZB driver cannot be activated, if I can install it, it has a windows config problem ...
Windows installs the following driver: <Silicon Labs CP210x USB to UARTBridge> on com7: ok for you ???
With that I can compile but I never managed to upload neither the bootloader nor a sketch.
I have tried with different versions of the arduino IDE. I am now fixed on 1.6.5 as recommended. I have tried with several versions of the <board manager> 2.1.7 up to 0.5.
I tried <rescue mode>, <reset factory mode> without success. I had messages "corrupted S2 key", "NEEDED: 1 GET: 0", various exceptions "Index error", "list index out of range", ...
I have tried with a Mac (and W7) without success.
However, I have a lot of experience with the arduino, but there, it starts to do a lot ...
Can you help ?
Eric
Ric1050
Re: z-uno communication problem on w7 64 ??
Post by Ric1050 »
with board 0.5
ARGS:C:\Users\Renard\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.02.01\zuno_toolchain\compiler.exe boot -p C:\Users\Renard\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\0.5.0/bootloaders/ -d COM7
VERSION:0.62b1 MD5:f60175422be690273c8cad00725cf5a2
INFO [2021-08-21 21:31:13,805] Status: Openning port
DEBUG [2021-08-21 21:31:13,822] >> 01 08 00 2A FF FF FF 00 10 32
ERROR [2021-08-21 21:31:13,822] 0 Could not write to serial port COM7: Unknown error: global name 'time' is not defined.
ERROR [2021-08-21 21:31:14,482] 1 returned 0 for ACK
ERROR [2021-08-21 21:31:14,482] 2 Unknown exception:list index out of range
INFO [2021-08-21 21:31:14,482]
Ric1050
Post by Ric1050 »
last try with board 2.1.7
Sketch uses 984 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 167 bytes of dynamic memory.
Openning port ..............................
Openning port .............................. OK
Stoping the user code ..............................
Stoping the user code .............................. OK
Closing port ..............................
Closing port .............................. OK
*** FOUND corrupted S2 key ***
NEW S2 KEYS
PRK:
HEX: F0 51 FB 40 B9 B5 DB 25 EF 19 E7 20 CA F9 5A 54 68 AF B4 19 BC CB B2 40 E6 B2 3F 1A 76 41 BB 70
DEC:61521-64320-47541-56101-61209-59168-51961-23124-26799-46105-48331-45632-59058-16154-30273-47984
PUK:
HEX: 1A 55 4D 67 96 B9 38 6E 85 FB 4E 2C 9B BB 10 3E 1A 97 36 59 E6 86 7A A2 69 CD 30 49 A6 EA E3 16
DEC:06741-19815-38585-14446-34299-20012-39867-04158-06807-13913-59014-31394-27085-12361-42730-58134
NEEDED:1 GET:0
NEEDED:1 GET:0
RAW Info:
FIRMWARE DATA
(<type 'exceptions.IndexError'>, 'compiler.py', 533)
Error 0 Unknown exception "list index out of range"
the selected serial port
does not exist or your board is not connected
Ric1050
Post by Ric1050 »
problem solved in 5 minutes. Thank you ;-)
Remember to document for other buyers of version 2 ...
Lot of time wasted for nothing ;-(
