Unable to use Z-uno 2 rev6
yves
Post by yves »
I am, for quite a long time now, using Z-uno001 (rev?) without any trouble. I recently ran out of stock (5 boards currently doing their job) and I order new ones (from Switzerland).
I have received 4 Z-uno 2 Rev 6 and Arduino is unable to speek with them. My Arduino is V1.6.5, freshly re-installed and board package is V2.1.7)
I hope you can help.
1rst Symptom:
When I select the Serial port , what i see is: TOOLS>PORT "COM6" instead of TOOLS>PORT "COM6 (Z-Wave>ME Z-Uno)"
2nd Symptom: when I try to run bootloader I get the following screen:
Openning port ..............................
Openning port .............................. OK
Stoping the user code ..............................
Stoping the user code .............................. OK
Closing port ..............................
Closing port .............................. OK
Error 0 Unknown exception:list index out of range
Last Symp^tom when Pushing sketch I get:
*** FOUND corrupted S2 key ***
NEW S2 KEYS
PRK:
HEX: 08 D1 87 AA 25 A5 B4 B4 51 47 38 0D 37 6A DD 3A 20 E2 16 06 61 13 2B A2 D9 DA CA 09 F1 12 99 59
DEC:02257-34730-09637-46260-20807-14349-14186-56634-08418-05638-24851-11170-55770-51721-61714-39257
PUK:
HEX: E4 9C 2C 69 F6 81 14 D0 7C 1F 4E A0 24 EF 3F A1 51 50 F4 E3 8E 6E E9 83 8C 01 49 1C 90 82 5D 1B
DEC:58524-11369-63105-05328-31775-20128-09455-16289-20816-62691-36462-59779-35841-18716-36994-23835
RAW Info:
FIRMWARE DATA
(<type 'exceptions.IndexError'>, 'compiler.py', 533)
Error 0 Unknown exception "list index out of range"
the selected serial port
does not exist or your board is not connected
I am running under windows10 64b. I have loaded the CP2102 USB drivers from silabs.com.
Arduino freshly resinstalled, PC restarted. Usb driver unistalled/reinstalled Rescue mode and factory reset tried.
Boards seem to be working (blinking white & green Leds, normal behaviour when entering rescue)
RQ when in above screen copy Arduino says Stoping the user code.............................. OK it is false, white led continue 'as if'.
If I plug the 'Z-Uno0001 HW" with the same config it works 100% without touching anything. But note that the two HW are not using same USB HW/drivers.
End of the day I am suspecting more and more the USB driver rather than Arduino?
I really hope that someone has an (good) idea?
Thanks in advance
Re: Unable to use Z-uno 2 rev6
yves
Post by yves »
Sorry My answer did not seems to have been transmitted. Here is the replay:
Yesss!!! it is working!
All my new Swiss boards are OK!
Just 2 comments:
* I was unable to burn V3.0.6 bootloader, I had to get back to package 3.0.5 to be able to push sketches.
Is that 'normal'?
* To my point of view loading Arduinoi IDE under "Microsoft Store" is not a good idea.
Place where windows install it is not 'easy' and access rights are set to 'no access' for most of them.
For ex: if you want to work with your own local libraries it is a nightmare. I finaly giveup and reinstall the 'normal' way.
Last: it is ok for simple sketches, for tricky ones I will wait documentation: some/many things have changed obviously....
Again Thank you!
Yves
