Is it possible to change Z-uno frequency in the bootloader?
Hi, does anyone know if for testing purposes it is possible to change the frequency of the device from on region to another programmatically or by changing the RF parameters in the bootloader?
Re: Is it possible to change Z-uno frequency in the bootloader?
Sure - from the UI or using config parameters: https://z-uno.z-wave.me/z-wave/configur ... arameters/ (param 9)
Thank you, very helpful. Do you have any specs for different antenna lengths for different frequencies?
On Z-Uno 1: 86 mm for EU, 82 for US
