EEPROM functions always return 0
aleconakad
Post by aleconakad »
using Z-Uno2 3.0.7, I have simple program that writes data to EEPROM, then reads out then compare it to verify if the write operation was successfull.
I use mainly read and write bulk operations, like put and get. I can confirm that the data has been written correctly to the EEPROM. the only issue is that the put and get functions always return 0, which results to false checks in my code. This behaviour is NOT compatible with Z-Uno first GEN.
Here's a code snippet:
if (EEPROM.put(addr, &write_array, asize))
    Serial.println("Flashing success");
  else {
    Serial.println("Flashing failed");
  if (EEPROM.get(addr, &read_array, asize*usize))
    Serial.println("EEPROM Read: success");
  else {
    Serial.println("EEPROM Read: failure");
    return;
Same behaviour in 3.0.8beta
joergm6
Re: EEPROM functions always return 0
Post by joergm6 »
An example looks like this, but is equal to the V1.
    Serial.println("Reading buffer from EEPROM...");
    res = EEPROM.get(addr, &read_data, sizeof(read_data));
    Serial.print("Read ");
    Serial.print(res);
    Serial.println(" Bytes");
    // write data to a specific address
    res = EEPROM.put(addr, &some_data, sizeof(some_data));
aleconakad
Hi joergm6,
what is the output of the code snippet above?
In my case it is:
13:04:57.218 -> Reading 128 Bytes one by one from EEPROM...
13:04:57.218 -> AA BB CC DD EE FF FF FF FF FF FF FF FF FF FF FF FF
13:04:57.218 -> FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 3C
13:04:57.251 -> 0 64 0 0 55 0 0 55 0 0 0 0 55 0 0 55
13:04:57.251 -> 55 0 0 55 0 0 0 0 55 0 0 55 55 0 0 55
13:04:57.251 -> 0 0 0 0 55 0 0 55 55 0 0 55 0 0 0 0
13:04:57.251 -> 55 0 0 55 55 0 0 55 0 0 0 0 55 0 0 55
13:04:57.251 -> 55 0 0 55 0 0 0 0 55 0 0 55 55 0 0 0
13:04:57.251 -> 0 0 55 0 0 0 0 0 55 0 0 0 0 0 0
13:04:57.251 -> Reading buffer from EEPROM...
13:04:57.285 -> Read 0 Bytes
compared to Zuno 1G, the results look lie this:
13:11:53.740 -> Reading 128 Bytes one by one from EEPROM...
13:11:53.740 -> AA BB CC DD EE 55 11 26 55 12 25 54 13 24 54 14 23
13:11:53.740 -> 53 15 22 52 16 21 52 17 20 51 17 1F 51 18 1E 3C
13:11:53.778 -> 0 64 0 0 55 0 0 55 0 0 0 0 55 0 0 55
13:11:53.778 -> 55 0 0 55 0 0 0 0 55 0 0 55 55 0 0 55
13:11:53.815 -> 0 0 0 0 55 0 0 55 55 0 0 55 0 0 0 0
13:11:53.815 -> 55 0 0 55 55 0 0 55 0 0 0 0 55 0 0 55
13:11:53.815 -> 55 0 0 55 0 0 0 0 55 0 0 55 55 0 0 0
13:11:53.851 -> 0 0 55 0 0 0 0 0 55 0 0 0 0 0 0
13:11:53.851 -> Reading buffer from EEPROM...
13:11:53.851 -> Read 1 Bytes
It seems that the function return 1 instead of 0. what does this `1` mean is something that the creators should be able to answer :-)
