Library for DMX protocol
ericSV
Post by ericSV »
Is it possible to have a library for the DMX protocol, for used the Z-Uno with a MAX485 serial ?
Thank's
Re: Library for DMX protocol
Yes, should be possible to port https://github.com/PaulStoffregen/DmxSimple on Z-Uno. The code is pretty small and should be easy to port. Feel free to contact us in case of questions. We can put it to our TODO queue, but it might take quite some time
ericSV
Post by ericSV »
I've an error.
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Eric\OneDrive\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Eric\OneDrive\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Eric\Documents\Arduino\libraries -fqbn=Z-Uno2:zw_cm4f:zuno2:Frequency=Ru,TXPower=Normal,RFLogging=Off,CleanNVM=Off,UpdateLicense=On -ide-version=10819 -build-path C:\Users\Eric\AppData\Local\Temp\arduino_build_493334 -warnings=all -build-cache C:\Users\Eric\AppData\Local\Temp\arduino_cache_978436 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\arm-none-eabi-gcc\7.2.4 -prefs=runtime.tools.arm-none-eabi-gcc-7.2.4.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\arm-none-eabi-gcc\7.2.4 -prefs=runtime.tools.libClang.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\libClang\11.0.1 -prefs=runtime.tools.libClang-11.0.1.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\libClang\11.0.1 -prefs=runtime.tools.zme_make.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\zme_make\0.4.1 -prefs=runtime.tools.zme_make-0.4.1.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\zme_make\0.4.1 -verbose C:\Users\Eric\Documents\ARDUINO\libraries\DmxSimple-master\examples\FadeUp\FadeUp.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\Eric\OneDrive\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\Eric\OneDrive\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\Eric\Documents\Arduino\libraries -fqbn=Z-Uno2:zw_cm4f:zuno2:Frequency=Ru,TXPower=Normal,RFLogging=Off,CleanNVM=Off,UpdateLicense=On -ide-version=10819 -build-path C:\Users\Eric\AppData\Local\Temp\arduino_build_493334 -warnings=all -build-cache C:\Users\Eric\AppData\Local\Temp\arduino_cache_978436 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\arm-none-eabi-gcc\7.2.4 -prefs=runtime.tools.arm-none-eabi-gcc-7.2.4.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\arm-none-eabi-gcc\7.2.4 -prefs=runtime.tools.libClang.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\libClang\11.0.1 -prefs=runtime.tools.libClang-11.0.1.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\libClang\11.0.1 -prefs=runtime.tools.zme_make.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\zme_make\0.4.1 -prefs=runtime.tools.zme_make-0.4.1.path=C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\tools\zme_make\0.4.1 -verbose C:\Users\Eric\Documents\ARDUINO\libraries\DmxSimple-master\examples\FadeUp\FadeUp.ino
Using board 'zuno2' from platform in folder: C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\hardware\zw_cm4f\3.0.10
Using core '/' from platform in folder: C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\hardware\zw_cm4f\3.0.10
Detecting libraries used...
"C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\tools\\zme_make\\0.4.1/zme_make" arduino_preproc "C:\\Users\\Eric\\AppData\\Local\\Temp\\arduino_build_493334\\sketch\\FadeUp.ino.cpp" "C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10/cores"
Found 1.8.x project structure (File:FadeUp.ino.cpp). Converting it...
INCREMENTAL PREPROC. The sketch is the same.
Generating function prototypes...
"C:\\Program Files\\WindowsApps\\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\Eric\\AppData\\Local\\Temp\\arduino_build_493334\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compilation du croquis...
"C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\tools\\zme_make\\0.4.1/zme_make" build "C:\\Users\\Eric\\AppData\\Local\\Temp\\arduino_build_493334/FadeUp.ino" -S "C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10/cores" -S "C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10/libraries" -S "C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\tools\\arm-none-eabi-gcc\\7.2.4/lib/gcc/arm-none-eabi/7.2.1/include" -B "C:\\Users\\Eric\\AppData\\Local\\Temp\\arduino_build_493334" -T "C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\tools\\arm-none-eabi-gcc\\7.2.4/bin" -O arduino_ide -lcl "C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\tools\\libClang\\11.0.1" -O BO:-DARDUINO=152 -O BO:-DARDUINO_ARCH_ZUNOG2 -O BO:-DZME_ZUNOG2 -O LO:-lm
***** Building sketch:C:\Users\Eric\AppData\Local\Temp\arduino_build_493334\FadeUp.ino *****
SOURCE LIST:['C:\\Users\\Eric\\AppData\\Local\\Temp\\arduino_build_493334\\', 'C:\\Users\\Eric\\AppData\\Local\\Temp\\arduino_build_493334\\core\\', 'C:\\Users\\Eric\\AppData\\Local\\Temp\\arduino_build_493334\\preproc\\', 'C:\\Users\\Eric\\AppData\\Local\\Temp\\arduino_build_493334\\sketch\\', 'C:\\Users\\Eric\\AppData\\Local\\Temp\\arduino_build_493334\\zuno_preproc\\', 'C:\\Users\\Eric\\AppData\\Local\\Temp\\arduino_build_493334\\sketch\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\cores\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\cores\\emlib\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\cores\\includes\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\cores\\libft\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\cores\\LLCore\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\cores\\ZWSupport\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\DallasTemperature\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\DmxSimple-master\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\Ds1307Rtc\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ModBusRtu\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\PN7150\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\PN7160\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\RF24\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\SpiFlash\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\Z-Uno-2G\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_AM2320\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_BMP180\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_BMP280\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_Buttons\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_CCS811\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_DAC102S085\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_DHTlib\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_DS18B20\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_FRAM\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_GFX\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_HDC1080\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_LCD\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_LEDS\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_MCP23XS17\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_MERCURY206R\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_ModBus\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_NeoPixel\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_Neptun\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_OneWire\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_SGP30\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_SHIELD\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_SOMFY\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\hardware\\zw_cm4f\\3.0.10\\libraries\\ZUNO_U8G2\\', 'C:\\Users\\Eric\\OneDrive\\Documents\\ArduinoData\\packages\\Z-Uno2\\tools\\arm-none-eabi-gcc\\7.2.4\\lib\\gcc\\arm-none-eabi\\7.2.1\\include\\']
preprocessing "FadeUp.ino" .............................. OK
Core version: 03.10 Channels:0
Gathering project files .............................. OK
C:\Users\Eric\OneDrive\Documents\ArduinoData\packages\Z-Uno2\hardware\zw_cm4f\3.0.10\libraries\DmxSimple-master\DmxSimple.cpp:7:10: fatal error: avr/io.h: No such file or directory
#include <avr/io.h>
compilation terminated.
exit status 10
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder a retourné 10
Erreur de compilation pour la carte Z-Wave>ME Z-Uno2
Can you help me ?
Thank's
You have to remove avr/io.h include file from sources and then check what was imported from that file to replace it with Z-Uno specific or your custom contrants.
