Z-Uno library for 433 MHz reciever
KGBEl
Post by KGBEl »
Hi, I have tried to use my Z-Uno with a 433 MHz reciever as intended in https://github.com/Xorok/FT007TH-Arduin ... orDemo.ino but without ethernet and Sd-card but it dosen't work.
So I tried this instead https://github.com/sui77/rc-switch/blob ... vanced.ino
but was not able to include RCSwitch.h, there was error during compilation.
I tried to use pin 18 and interrupt, without RCSwitch it compiled ok but did not show any output from the reciever.
Is it not possible to use Z-Uno instead of Arduino Uno?
Is there a specifik Z-Uno library that should be used?
Re: Z-Uno library for 433 MHz reciever
Sure, it is possible to port RCSwitch to Z-Uno hardware, but you need to port it. We have no such library yet.
KGBEl
Post by KGBEl »
Sorry for my bad english but what is port?
No problem. Porting source code means adopting the code to fit another environment. Z-Uno 2 environment is a bit different from Arduino
KGBEl
Post by KGBEl »
Ok, thank you, I understand that this will be a job for an experienced programmer.
Do you know if something like that has been done before?
Sure, many libraries were ported by us and the community. But not for this one yet
KGBEl
Post by KGBEl »
Hi again, thanks for answer, can you just
give me an example of two files, befor and after porting,
so I may understand what has to be changed and how?
You can look on any lib here: https://github.com/Z-Wave-Me/Z-Uno-G2-C ... /libraries
And find the corresponding one in Arduino. Some are very very different (like NeoPixel) as they rely on ASM code a lot.
