html not interpreted
Moderator: DomotikQuebec
bmflorant@yahoo.fr
Post by bmflorant@yahoo.fr »
Hello everybody,
I am new on Z-wave /Razberrry. I just installed Z-way. I happened to see brievely the web interface on 127.0.0.1:8083, but rapidly, my browser doesn't interpret html anymore.
I can only see the html code.
An idea of the origin of my problem ?
Thank you !
silverhack
Re: html not interpreted
Post by silverhack »
Try rebooting your computer, and make sure you are able to browse other websites correctly.
bmflorant@yahoo.fr
Thank you for answering.
I have installed chromium and the browser can now interprete html.
thetof
Post by thetof »
Bonjour à tous,
Je rencontre le même problème que bmflorant@yahoo.fr : sur le 8083, je vois très rapidement l'interface, puis le navigateur affiche le code html de la page.
Sur les autres sites, aucun problème.
Le reboot n'a rien changé, et l'arret/relance du service non plus.
Si quelqu'un aurait une idée, je suis preneur ;)
Autre question : comment être sur que la carte Razberry fonctionne correctement? Bien alimentée? Port GPIO qui est activé ?
Merci d'avance à tous
thetof
Post by thetof »
Problème finalement résolu en changeant de navigateur (de Epiphany vers Chromium)
Merci, et à bientot
lok907
Post by lok907 »
bmflorant@yahoo.fr wrote:
27 May 2016 21:49
Hello everybody,
Thank you !
First take a backup of your device and do factory reset.
arnolddk0
Post by arnolddk0 »
you have to click the administrator permission of HTML on pc. YoWhatsApp APK Download
arunsdz
Post by arunsdz »
html not interpreted, Generally this occurs when you cant reach the servers. You may try FM Whatsappnew browser through which you can get access. This is not a language error it contains some data that shows the error. Hope some could get the solution and post over here.
Where and when does it happen?
arddk
Post by arddk »
it represents, not a program, but some data.html not interpreted.
WhatsApp Plus Download
