My plan was to chang my doorbell from the orginal ding dong, and let the sonos play something But i dont get it to work. I have don it exatly like this picture
http://www.zwaveforum.se/download/file.php?id=52
but without "dörrklocka" and that works with "vera" you only change parameter 3 till no normaly open. when i push the button nothing happens in raz ui i only says "idle", is there some other parameter i need to change?
Fibaro universal binary sensor
As soon as you release the
As soon as you release the button, the status returns to idle. Did you hold it in your test?
Nothing happens
Nothing happens when i push the button
Strange, in my application I
Strange, in my application I also do connect the IN terminals to GND. That works fine for me (http://www.openremote.org/display/docs/ ... sal+Sensor)
What version of RaZberry are
What version of RaZberry are you using? Check 'Expert mode', Controller Info
I use the version 1.4.1-rc1 and then the inputs are working fine again
Well, the trick was to modify
Well, the trick was to modify the content from the link published
http://razberry.z-wave.me/install
and to create a script yourself where you can edit it to point to another version
How to upgrade:
Paste the link above in a browser and then 'save as' the page to a text file, i.e. install.sh
0) Edit the install.sh correctly with name of new package to be installed like: "wget -q http://razberry.z-wave.me/z-way-server- ... .1-rc1.tgz -O - | tar -zx
1) Copy the install.sh to /Home/pi
2) Stop the Z-Way: "sudo /etc/init.d/Z-Way stop"
3) Run the script: "sudo bash install.sh"
You should now be done, check via the GUI that the correct version is running
If you need to go back to older version, do as follows:
1) Stop the Z-Way: "sudo /etc/init.d/Z-Way stop"
2) Rename directories, as example: "mv /opt/z-way-server /opt/z-way-server.1.4.1_rc1" and then "sudo mv /opt/z-way-server_2013-11-01-08-19-15 /opt/z-way-server"
3) Start the Z-Way: "sudo /etc/init.d/Z-Way start"
How to upgrade:
Recently the 1.4.1_rc1
Recently the 1.4.1_rc1 release has silently been renamed to 1.4.1. So the normal update procedure should work:
