pz1
Posts: 2053 Joined: 08 Apr 2012 13:44
Post
by pz1 » 07 Jul 2014 20:30
I did revert tom 1.4.1, the last stable version I had. The battery polling "rule" let the system hang after a couple of days. I had to reload the HA user interface a couple of times before all elements became visible. In the end the whole system hung, and I had to re-install everything (well actually copy the lates image I had saved).
The very reason to go back to 1.4.1 was in the fact that I could not install and configure my second Fibaro Universal Sensor. Also the exclusion/inclusion of my working Fibaro failed on 1.7.1. As this this did work in 1.4.1 I took that version. And indeed the Fibaro was included correctly again.
PS: I did send error reports on the polling thing twice. The comment was that I was using the wrong (outdated) js code. That was true for the first report, but not for the second.
I'll see what is coming with next releases. In the meantime I take a break
pz1 on 02 Aug 2014 20:53, edited 1 time in total.
pofs
Posts: 688 Joined: 25 Mar 2011 19:03
Post
by pofs » 08 Jul 2014 15:28
I could not believe exclusion might fail because of different Z-Way version. The same goes for inclusion – both these operations are performed by controller hardware, and don't depend on software version.
The only thing could fail is device interview. We've made some changes in queue handling and interview sequence since 1.4.1, also new command classes were added.
If the problem is interview not passed, then we need more details. Log fragment and a list of failed CCs are highly appreciated.
pz1
Post
by pz1 » 08 Jul 2014 15:47
pofs wrote: I could not believe exclusion might fail because of different Z-Way version.
You better believe it. I have been wrestling and serious testing for over a week. Going back and forward between versions twice!
Because I am too fed up at the moment, I am not going to spend more time on logs etc. I have done so with the battery polling problems with little success.
I do appreciate your help, but for now I need a break on this. Wait and see for a while if and how others respond.
Thanks for the moment.
pofs
Post
by pofs » 08 Jul 2014 16:09
You've tested it over a week and didn't save a single log to report an issue?
pz1
Post
by pz1 » 08 Jul 2014 16:34
Indeed I did not bother to save logs, since sending logs has not brought me much so far.
pz1
Post
by pz1 » 08 Jul 2014 20:32
@pofs
Fired up RaZ with fresh 1.7.1 image.
Excluded the FUS, followed by an Inclusion. Under sensors I only see the two binary sensors but none of the temperature sensors. I had one temp sensor connected. That sensor is visible in 1.4.1
I think this is the relevant portion of the log
[2014-07-08 17:03:16.855] Executing script: zway.controller.AddNodeToNetwork(1)
[2014-07-08 17:03:16.856] Adding job: Add/re-include node to network
[2014-07-08 17:03:16.865] SENDING (cb 0xa2): ( 01 05 00 4A C1 A2 D3 )
[2014-07-08 17:03:16.876] RECEIVED ACK
[2014-07-08 17:03:16.886] RECEIVED: ( 01 07 00 4A A2 01 00 00 11 )
[2014-07-08 17:03:16.887] SENT ACK
[2014-07-08 17:03:16.887] SETDATA controller.data.lastIncludedDevice = Empty
[2014-07-08 17:03:16.887] SETDATA controller.data.lastExcludedDevice = Empty
[2014-07-08 17:03:16.887] Job 0x4a (Add/re-include node to network): Ready to add - push button on the device to be added
[2014-07-08 17:03:16.887] SETDATA controller.data.controllerState = 1 (0x00000001)
[2014-07-08 17:03:20.301] RECEIVED: ( 01 14 00 4A A2 02 27 0D 04 20 01 60 85 8E 72 70 86 EF 2B 31 9C 88 )
[2014-07-08 17:03:20.301] SENT ACK
[2014-07-08 17:03:20.301] Job 0x4a (Add/re-include node to network): Node found: #39
[2014-07-08 17:03:20.302] SETDATA controller.data.controllerState = 2 (0x00000002)
[2014-07-08 17:03:20.302] SETDATA devices.39.data.basicType = 4 (0x00000004)
[2014-07-08 17:03:20.302] SETDATA devices.39.data.genericType = 32 (0x00000020)
[2014-07-08 17:03:20.302] SETDATA devices.39.data.specificType = 1 (0x00000001)
[2014-07-08 17:03:20.306] SETDATA devices.39.data.deviceTypeString = "Routing Binary Sensor"
[2014-07-08 17:03:20.306] SETDATA devices.39.data.nodeInfoFrame = byte[10]
( 60 85 8E 72 70 86 EF 2B 31 9C )
[2014-07-08 17:03:20.317] RECEIVED: ( 01 14 00 4A A2 03 27 0D 04 20 01 60 85 8E 72 70 86 EF 2B 31 9C 89 )
[2014-07-08 17:03:20.317] SENT ACK
[2014-07-08 17:03:20.317] Job 0x4a (Add/re-include node to network): Adding slave: #39
[2014-07-08 17:03:20.317] SETDATA controller.data.controllerState = 3 (0x00000003)
[2014-07-08 17:03:20.317] SETDATA controller.data.lastIncludedDevice = 39 (0x00000027)
[2014-07-08 17:03:20.318] SETDATA devices.39.data.basicType = 4 (0x00000004)
[2014-07-08 17:03:20.318] SETDATA devices.39.data.genericType = 32 (0x00000020)
[2014-07-08 17:03:20.318] SETDATA devices.39.data.specificType = 1 (0x00000001)
[2014-07-08 17:03:20.322] SETDATA devices.39.data.deviceTypeString = "Routing Binary Sensor"
[2014-07-08 17:03:20.322] SETDATA devices.39.data.nodeInfoFrame = byte[10]
[2014-07-08 17:03:20.333] RECEIVED: ( 01 14 00 4A A2 05 27 0D 04 20 01 60 85 8E 72 70 86 EF 2B 31 9C 8F )
[2014-07-08 17:03:20.333] SENT ACK
[2014-07-08 17:03:20.333] Job 0x4a (Add/re-include node to network): Protocol done
[2014-07-08 17:03:20.333] SETDATA controller.data.controllerState = 4 (0x00000004)
[2014-07-08 17:03:20.334] Adding job: Add/re-include node to network
[2014-07-08 17:03:20.334] Loading Command Classes for device 39
[2014-07-08 17:03:20.337] Node 39:0 supports CC MultiChannel
[2014-07-08 17:03:20.337] SETDATA devices.39.instances.0.commandClasses.96.data = Empty
[2014-07-08 17:03:20.337] SETDATA devices.39.instances.0.commandClasses.96.data.supported = Empty
[2014-07-08 17:03:20.338] SETDATA devices.39.instances.0.commandClasses.96.data.supported = True
[2014-07-08 17:03:20.338] SETDATA devices.39.instances.0.commandClasses.96.data.version = Empty
[2014-07-08 17:03:20.338] SETDATA devices.39.instances.0.commandClasses.96.data.version = 1 (0x00000001)
[2014-07-08 17:03:20.338] SETDATA devices.39.instances.0.commandClasses.96.data.security = Empty
[2014-07-08 17:03:20.338] SETDATA devices.39.instances.0.commandClasses.96.data.security = False
[2014-07-08 17:03:20.338] SETDATA devices.39.instances.0.commandClasses.96.data.interviewDone = Empty
[2014-07-08 17:03:20.339] SETDATA devices.39.instances.0.commandClasses.96.data.interviewCounter = Empty
[2014-07-08 17:03:20.339] SETDATA devices.39.instances.0.commandClasses.96.data.interviewDone = False
[2014-07-08 17:03:20.339] SETDATA devices.39.instances.0.commandClasses.96.data.interviewCounter = 10 (0x0000000a)
[2014-07-08 17:03:20.339] SETDATA devices.39.instances.0.commandClasses.96.data.endPoints = Empty
[2014-07-08 17:03:20.343] SETDATA devices.39.instances.0.commandClasses.96.data.endPoints = 0 (0x00000000)
[2014-07-08 17:03:20.343] SETDATA devices.39.instances.0.commandClasses.96.data.dynamic = Empty
[2014-07-08 17:03:20.344] SETDATA devices.39.instances.0.commandClasses.96.data.identical = Empty
[2014-07-08 17:03:20.343] Deleting device sensorBinary ZWayVDev_39:1:48:1
[2014-07-08 17:03:20.346] Node 39:0 supports CC Configuration
[2014-07-08 17:03:20.346] SETDATA devices.39.instances.0.commandClasses.112.data = Empty
[2014-07-08 17:03:20.346] SETDATA devices.39.instances.0.commandClasses.112.data.supported = Empty
[2014-07-08 17:03:20.346] SETDATA devices.39.instances.0.commandClasses.112.data.supported = True
[2014-07-08 17:03:20.347] SETDATA devices.39.instances.0.commandClasses.112.data.version = Empty
[2014-07-08 17:03:20.347] SETDATA devices.39.instances.0.commandClasses.112.data.version = 1 (0x00000001)
[2014-07-08 17:03:20.347] SETDATA devices.39.instances.0.commandClasses.112.data.security = Empty
[2014-07-08 17:03:20.347] SETDATA devices.39.instances.0.commandClasses.112.data.security = False
[2014-07-08 17:03:20.347] SETDATA devices.39.instances.0.commandClasses.112.data.interviewDone = Empty
[2014-07-08 17:03:20.347] SETDATA devices.39.instances.0.commandClasses.112.data.interviewCounter = Empty
[2014-07-08 17:03:20.347] SETDATA devices.39.instances.0.commandClasses.112.data.interviewDone = False
[2014-07-08 17:03:20.347] SETDATA devices.39.instances.0.commandClasses.112.data.interviewCounter = 10 (0x0000000a)
[2014-07-08 17:03:20.348] Node 39:0 supports CC ManufacturerSpecific
[2014-07-08 17:03:20.348] SETDATA devices.39.instances.0.commandClasses.114.data = Empty
[2014-07-08 17:03:20.348] SETDATA devices.39.instances.0.commandClasses.114.data.supported = Empty
[2014-07-08 17:03:20.348] SETDATA devices.39.instances.0.commandClasses.114.data.supported = True
[2014-07-08 17:03:20.348] SETDATA devices.39.instances.0.commandClasses.114.data.version = Empty
[2014-07-08 17:03:20.349] SETDATA devices.39.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2014-07-08 17:03:20.349] SETDATA devices.39.instances.0.commandClasses.114.data.security = Empty
[2014-07-08 17:03:20.349] SETDATA devices.39.instances.0.commandClasses.114.data.security = False
[2014-07-08 17:03:20.349] SETDATA devices.39.instances.0.commandClasses.114.data.interviewDone = Empty
[2014-07-08 17:03:20.349] SETDATA devices.39.instances.0.commandClasses.114.data.interviewCounter = Empty
[2014-07-08 17:03:20.349] SETDATA devices.39.instances.0.commandClasses.114.data.interviewDone = False
[2014-07-08 17:03:20.349] SETDATA devices.39.instances.0.commandClasses.114.data.interviewCounter = 10 (0x0000000a)
[2014-07-08 17:03:20.349] SETDATA devices.39.instances.0.commandClasses.114.data.vendorId = Empty
[2014-07-08 17:03:20.350] SETDATA devices.39.instances.0.commandClasses.114.data.vendor = Empty
[2014-07-08 17:03:20.350] SETDATA devices.39.instances.0.commandClasses.114.data.productId = Empty
[2014-07-08 17:03:20.350] SETDATA devices.39.instances.0.commandClasses.114.data.productType = Empty
[2014-07-08 17:03:20.350] Node 39:0 supports CC Association
[2014-07-08 17:03:20.350] SETDATA devices.39.instances.0.commandClasses.133.data = Empty
[2014-07-08 17:03:20.350] SETDATA devices.39.instances.0.commandClasses.133.data.supported = Empty
[2014-07-08 17:03:20.351] SETDATA devices.39.instances.0.commandClasses.133.data.supported = True
[2014-07-08 17:03:20.351] SETDATA devices.39.instances.0.commandClasses.133.data.version = Empty
[2014-07-08 17:03:20.351] SETDATA devices.39.instances.0.commandClasses.133.data.version = 1 (0x00000001)
[2014-07-08 17:03:20.351] SETDATA devices.39.instances.0.commandClasses.133.data.security = Empty
[2014-07-08 17:03:20.351] SETDATA devices.39.instances.0.commandClasses.133.data.security = False
[2014-07-08 17:03:20.351] SETDATA devices.39.instances.0.commandClasses.133.data.interviewDone = Empty
[2014-07-08 17:03:20.351] SETDATA devices.39.instances.0.commandClasses.133.data.interviewCounter = Empty
[2014-07-08 17:03:20.351] SETDATA devices.39.instances.0.commandClasses.133.data.interviewDone = False
[2014-07-08 17:03:20.352] SETDATA devices.39.instances.0.commandClasses.133.data.interviewCounter = 10 (0x0000000a)
[2014-07-08 17:03:20.352] SETDATA devices.39.instances.0.commandClasses.133.data.groups = Empty
[2014-07-08 17:03:20.352] Node 39:0 supports CC Version
[2014-07-08 17:03:20.352] SETDATA devices.39.instances.0.commandClasses.134.data = Empty
[2014-07-08 17:03:20.352] SETDATA devices.39.instances.0.commandClasses.134.data.supported = Empty
[2014-07-08 17:03:20.352] SETDATA devices.39.instances.0.commandClasses.134.data.supported = True
[2014-07-08 17:03:20.353] SETDATA devices.39.instances.0.commandClasses.134.data.version = Empty
[2014-07-08 17:03:20.353] SETDATA devices.39.instances.0.commandClasses.134.data.version = 1 (0x00000001)
[2014-07-08 17:03:20.353] SETDATA devices.39.instances.0.commandClasses.134.data.security = Empty
[2014-07-08 17:03:20.353] SETDATA devices.39.instances.0.commandClasses.134.data.security = False
[2014-07-08 17:03:20.354] Deleting device sensorBinary ZWayVDev_39:2:48:1
[2014-07-08 17:03:20.353] SETDATA devices.39.instances.0.commandClasses.134.data.interviewDone = Empty
[2014-07-08 17:03:20.356] SETDATA devices.39.instances.0.commandClasses.134.data.interviewCounter = Empty
[2014-07-08 17:03:20.356] SETDATA devices.39.instances.0.commandClasses.134.data.interviewDone = False
[2014-07-08 17:03:20.356] SETDATA devices.39.instances.0.commandClasses.134.data.interviewCounter = 10 (0x0000000a)
[2014-07-08 17:03:20.357] SETDATA devices.39.instances.0.commandClasses.134.data.ZWLib = Empty
[2014-07-08 17:03:20.357] SETDATA devices.39.instances.0.commandClasses.134.data.ZWProtocolMajor = Empty
[2014-07-08 17:03:20.357] SETDATA devices.39.instances.0.commandClasses.134.data.ZWProtocolMinor = Empty
[2014-07-08 17:03:20.357] SETDATA devices.39.instances.0.commandClasses.134.data.SDK = Empty
[2014-07-08 17:03:20.357] SETDATA devices.39.instances.0.commandClasses.134.data.applicationMajor = Empty
[2014-07-08 17:03:20.357] SETDATA devices.39.instances.0.commandClasses.134.data.applicationMinor = Empty
[2014-07-08 17:03:20.357] SETDATA devices.39.instances.0.commandClasses.134.data.hardwareVersion = Empty
[2014-07-08 17:03:20.358] SETDATA devices.39.instances.0.commandClasses.134.data.firmwareCount = Empty
[2014-07-08 17:03:20.358] Node 39:0 supports CC MultiChannelAssociation
[2014-07-08 17:03:20.358] SETDATA devices.39.instances.0.commandClasses.142.data = Empty
[2014-07-08 17:03:20.358] SETDATA devices.39.instances.0.commandClasses.142.data.supported = Empty
[2014-07-08 17:03:20.358] SETDATA devices.39.instances.0.commandClasses.142.data.supported = True
[2014-07-08 17:03:20.358] SETDATA devices.39.instances.0.commandClasses.142.data.version = Empty
[2014-07-08 17:03:20.359] SETDATA devices.39.instances.0.commandClasses.142.data.version = 1 (0x00000001)
[2014-07-08 17:03:20.359] SETDATA devices.39.instances.0.commandClasses.142.data.security = Empty
[2014-07-08 17:03:20.359] SETDATA devices.39.instances.0.commandClasses.142.data.security = False
[2014-07-08 17:03:20.359] SETDATA devices.39.instances.0.commandClasses.142.data.interviewDone = Empty
[2014-07-08 17:03:20.359] SETDATA devices.39.instances.0.commandClasses.142.data.interviewCounter = Empty
[2014-07-08 17:03:20.359] SETDATA devices.39.instances.0.commandClasses.142.data.interviewDone = False
[2014-07-08 17:03:20.359] SETDATA devices.39.instances.0.commandClasses.142.data.interviewCounter = 10 (0x0000000a)
[2014-07-08 17:03:20.360] SETDATA devices.39.instances.0.commandClasses.142.data.groups = Empty
[2014-07-08 17:03:20.360] SETDATA devices.39.data.lastSend = 541099 (0x000841ab)
[2014-07-08 17:03:20.360] SETDATA devices.39.data.isAwake = True
[2014-07-08 17:03:20.360] SETDATA devices.39.data.lastSend = 540999 (0x00084147)
[2014-07-08 17:03:20.360] SETDATA devices.39.data.lastNonceGet = 539999 (0x00083d5f)
[2014-07-08 17:03:20.361] Interview step 1
[2014-07-08 17:03:20.361] SETDATA devices.39.instances.0.commandClasses.134.data.interviewDone = False
[2014-07-08 17:03:20.361] SETDATA devices.39.instances.0.commandClasses.134.data.interviewCounter = 9 (0x00000009)
[2014-07-08 17:03:20.362] Node 39:0 CC Version Interview started
[2014-07-08 17:03:20.362] Adding job: MultiChannel Version Get
[2014-07-08 17:03:20.362] Adding job: Configuration Version Get
[2014-07-08 17:03:20.362] Adding job: ManufacturerSpecific Version Get
[2014-07-08 17:03:20.362] Adding job: Association Version Get
[2014-07-08 17:03:20.363] Adding job: Version Version Get
[2014-07-08 17:03:20.363] Adding job: MultiChannelAssociation Version Get
[2014-07-08 17:03:20.363] Running wakeup handler for node 39
[2014-07-08 17:03:20.375] SENDING (cb 0x05): ( 01 04 00 4A 05 B4 )
[2014-07-08 17:03:20.385] RECEIVED ACK
[2014-07-08 17:03:20.386] Removing job: Add/re-include node to network
[2014-07-08 17:03:20.430] RECEIVED: ( 01 07 00 4A A2 06 27 00 31 )
[2014-07-08 17:03:20.430] SENT ACK
[2014-07-08 17:03:20.430] Job 0x4a (Add/re-include node to network): Done
[2014-07-08 17:03:20.430] SETDATA controller.data.controllerState = 0 (0x00000000)
[2014-07-08 17:03:20.431] Job 0x4a (Add/re-include node to network): success
[2014-07-08 17:03:20.431] Removing job: Add/re-include node to network
[2014-07-08 17:03:20.442] SENDING (cb 0xa3): ( 01 0A 00 13 27 03 86 13 60 25 A3 B1 )
[2014-07-08 17:03:20.453] RECEIVED ACK
[2014-07-08 17:03:20.463] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-07-08 17:03:20.463] SENT ACK
[2014-07-08 17:03:20.464] Delivered to Z-Wave stack
pofs
Post
by pofs » 09 Jul 2014 02:35
Unfortunately, the most relevant part of the log (MultiChannel interview) is beyond the quoted fragment. Need more log.
pz1
Post
by pz1 » 09 Jul 2014 10:15
This is the continuation of the log:
[2014-07-08 17:03:20.474] RECEIVED: ( 01 05 00 13 A3 00 4A )
[2014-07-08 17:03:20.474] SENT ACK
[2014-07-08 17:03:20.474] Job 0x13 (MultiChannel Version Get): Delivered
[2014-07-08 17:03:20.475] SETDATA devices.39.data.lastPacketInfo.delivered = True
[2014-07-08 17:03:20.475] SETDATA devices.39.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-07-08 17:03:20.475] SETDATA devices.39.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2014-07-08 17:03:20.475] SETDATA devices.39.data.lastPacketInfo = **********
[2014-07-08 17:03:20.475] SendData Response with callback 0xa3 received: received by recipient
[2014-07-08 17:03:20.476] SETDATA devices.39.data.lastSend = 541009 (0x00084151)
[2014-07-08 17:03:20.476] Job 0x13 (MultiChannel Version Get): success
[2014-07-08 17:03:20.476] Removing job: MultiChannel Version Get
[2014-07-08 17:03:20.486] RECEIVED: ( 01 0A 00 04 00 27 04 86 14 60 02 22 )
[2014-07-08 17:03:20.487] SENT ACK
[2014-07-08 17:03:20.487] SETDATA devices.39.data.lastReceived = 0 (0x00000000)
[2014-07-08 17:03:20.487] Node 39:0 CC Version: MultiChannel is v2
[2014-07-08 17:03:20.487] SETDATA devices.39.instances.0.commandClasses.96.data.version = 2 (0x00000002)
[2014-07-08 17:03:20.544] SENDING (cb 0xa4): ( 01 0A 00 13 27 03 86 13 70 25 A4 A6 )
[2014-07-08 17:03:20.555] RECEIVED ACK
[2014-07-08 17:03:20.565] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-07-08 17:03:20.565] SENT ACK
[2014-07-08 17:03:20.566] Delivered to Z-Wave stack
[2014-07-08 17:03:20.576] RECEIVED: ( 01 05 00 13 A4 00 4D )
[2014-07-08 17:03:20.576] SENT ACK
[2014-07-08 17:03:20.576] Job 0x13 (Configuration Version Get): Delivered
[2014-07-08 17:03:20.577] SETDATA devices.39.data.lastPacketInfo.delivered = True
[2014-07-08 17:03:20.577] SETDATA devices.39.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-07-08 17:03:20.577] SETDATA devices.39.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2014-07-08 17:03:20.577] SETDATA devices.39.data.lastPacketInfo = **********
[2014-07-08 17:03:20.577] SendData Response with callback 0xa4 received: received by recipient
[2014-07-08 17:03:20.577] SETDATA devices.39.data.lastSend = 541018 (0x0008415a)
[2014-07-08 17:03:20.578] Job 0x13 (Configuration Version Get): success
[2014-07-08 17:03:20.578] Removing job: Configuration Version Get
[2014-07-08 17:03:20.588] RECEIVED: ( 01 0A 00 04 00 27 04 86 14 70 01 31 )
[2014-07-08 17:03:20.589] SENT ACK
[2014-07-08 17:03:20.589] SETDATA devices.39.data.lastReceived = 0 (0x00000000)
[2014-07-08 17:03:20.589] Node 39:0 CC Version: Configuration is v1
[2014-07-08 17:03:20.589] SETDATA devices.39.instances.0.commandClasses.112.data.version = 1 (0x00000001)
[2014-07-08 17:03:20.646] SENDING (cb 0xa5): ( 01 0A 00 13 27 03 86 13 72 25 A5 A5 )
[2014-07-08 17:03:20.657] RECEIVED ACK
[2014-07-08 17:03:20.667] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-07-08 17:03:20.668] SENT ACK
[2014-07-08 17:03:20.668] Delivered to Z-Wave stack
[2014-07-08 17:03:20.678] RECEIVED: ( 01 05 00 13 A5 00 4C )
[2014-07-08 17:03:20.679] SENT ACK
[2014-07-08 17:03:20.679] Job 0x13 (ManufacturerSpecific Version Get): Delivered
[2014-07-08 17:03:20.679] SETDATA devices.39.data.lastPacketInfo.delivered = True
[2014-07-08 17:03:20.679] SETDATA devices.39.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-07-08 17:03:20.679] SETDATA devices.39.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2014-07-08 17:03:20.679] SETDATA devices.39.data.lastPacketInfo = **********
[2014-07-08 17:03:20.680] SendData Response with callback 0xa5 received: received by recipient
[2014-07-08 17:03:20.680] SETDATA devices.39.data.lastSend = 541027 (0x00084163)
[2014-07-08 17:03:20.680] Job 0x13 (ManufacturerSpecific Version Get): success
[2014-07-08 17:03:20.680] Removing job: ManufacturerSpecific Version Get
[2014-07-08 17:03:20.690] RECEIVED: ( 01 0A 00 04 00 27 04 86 14 72 01 33 )
[2014-07-08 17:03:20.691] SENT ACK
[2014-07-08 17:03:20.691] SETDATA devices.39.data.lastReceived = 0 (0x00000000)
[2014-07-08 17:03:20.691] Node 39:0 CC Version: ManufacturerSpecific is v1
[2014-07-08 17:03:20.691] SETDATA devices.39.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2014-07-08 17:03:20.748] SENDING (cb 0xa6): ( 01 0A 00 13 27 03 86 13 85 25 A6 51 )
[2014-07-08 17:03:20.759] RECEIVED ACK
[2014-07-08 17:03:20.778] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-07-08 17:03:20.778] SENT ACK
[2014-07-08 17:03:20.778] Delivered to Z-Wave stack
[2014-07-08 17:03:20.789] RECEIVED: ( 01 05 00 13 A6 00 4F )
[2014-07-08 17:03:20.789] SENT ACK
[2014-07-08 17:03:20.789] Job 0x13 (Association Version Get): Delivered
[2014-07-08 17:03:20.789] SETDATA devices.39.data.lastPacketInfo.delivered = True
[2014-07-08 17:03:20.790] SETDATA devices.39.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-07-08 17:03:20.790] SETDATA devices.39.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2014-07-08 17:03:20.790] SETDATA devices.39.data.lastPacketInfo = **********
[2014-07-08 17:03:20.790] SendData Response with callback 0xa6 received: received by recipient
[2014-07-08 17:03:20.790] SETDATA devices.39.data.lastSend = 541036 (0x0008416c)
[2014-07-08 17:03:20.790] Job 0x13 (Association Version Get): success
[2014-07-08 17:03:20.791] Removing job: Association Version Get
[2014-07-08 17:03:20.801] RECEIVED: ( 01 0A 00 04 00 27 04 86 14 85 02 C7 )
[2014-07-08 17:03:20.802] SENT ACK
[2014-07-08 17:03:20.802] SETDATA devices.39.data.lastReceived = 0 (0x00000000)
[2014-07-08 17:03:20.802] Node 39:0 CC Version: Association is v2
[2014-07-08 17:03:20.802] SETDATA devices.39.instances.0.commandClasses.133.data.version = 2 (0x00000002)
[2014-07-08 17:03:20.877] RECEIVED: ( 01 08 00 04 00 19 02 84 07 6B )
[2014-07-08 17:03:20.877] SENT ACK
[2014-07-08 17:03:20.877] SETDATA devices.25.data.lastReceived = 0 (0x00000000)
[2014-07-08 17:03:20.878] Node 25:0 CC Wakeup: Wakeup notification
[2014-07-08 17:03:20.878] SETDATA devices.25.instances.0.commandClasses.132.data.lastWakeup = 1404839000 (0x53bc2458)
[2014-07-08 17:03:20.878] SETDATA devices.25.data.isAwake = True
[2014-07-08 17:03:20.878] SETDATA devices.25.data.lastSend = 541043 (0x00084173)
[2014-07-08 17:03:20.878] SETDATA devices.25.data.lastNonceGet = 540043 (0x00083d8b)
[2014-07-08 17:03:20.878] Running wakeup handler for node 25
[2014-07-08 17:03:20.879] SETDATA devices.25.instances.0.commandClasses.132.data.lastSleep = 1404839000 (0x53bc2458)
[2014-07-08 17:03:20.879] Node 25:0 CC Wakeup: Send node to sleep
[2014-07-08 17:03:20.879] Adding job: Wakeup Sleep
[2014-07-08 17:03:20.879] SENDING (cb 0xa7): ( 01 0A 00 13 27 03 86 13 86 25 A7 53 )
[2014-07-08 17:03:20.890] RECEIVED ACK
[2014-07-08 17:03:20.900] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-07-08 17:03:20.901] SENT ACK
[2014-07-08 17:03:20.901] Delivered to Z-Wave stack
[2014-07-08 17:03:20.911] RECEIVED: ( 01 05 00 13 A7 00 4E )
[2014-07-08 17:03:20.911] SENT ACK
[2014-07-08 17:03:20.912] Job 0x13 (Version Version Get): Delivered
[2014-07-08 17:03:20.912] SETDATA devices.39.data.lastPacketInfo.delivered = True
[2014-07-08 17:03:20.912] SETDATA devices.39.data.lastPacketInfo.packetLength = 6 (0x00000006)
[2014-07-08 17:03:20.912] SETDATA devices.39.data.lastPacketInfo.deliveryTime = 10 (0x0000000a)
[2014-07-08 17:03:20.912] SETDATA devices.39.data.lastPacketInfo = **********
[2014-07-08 17:03:20.912] SendData Response with callback 0xa7 received: received by recipient
[2014-07-08 17:03:20.913] SETDATA devices.39.data.lastSend = 541046 (0x00084176)
[2014-07-08 17:03:20.913] Job 0x13 (Version Version Get): success
[2014-07-08 17:03:20.913] Removing job: Version Version Get
[2014-07-08 17:03:20.923] RECEIVED: ( 01 0A 00 04 00 27 04 86 14 86 01 C7 )
[2014-07-08 17:03:20.924] SENT ACK
[2014-07-08 17:03:20.924] SETDATA devices.39.data.lastReceived = 0 (0x00000000)
[2014-07-08 17:03:20.924] Node 39:0 CC Version: Version is v1
[2014-07-08 17:03:20.924] SETDATA devices.39.instances.0.commandClasses.134.data.version = 1 (0x00000001)
[2014-07-08 17:03:20.925] Adding job: Version Get
[2014-07-08 17:03:20.948] SENDING (cb 0xa8): ( 01 09 00 13 19 02 84 08 05 A8 DF )
[2014-07-08 17:03:20.958] RECEIVED ACK
[2014-07-08 17:03:20.969] RECEIVED: ( 01 04 01 13 01 E8 )
[2014-07-08 17:03:20.969] SENT ACK
[2014-07-08 17:03:20.969] Delivered to Z-Wave stack
Edit 20140713: In the meantime I have returned my two FUS devices to my supplier who is kind enough to test both with his equipment.
pz1
Post
by pz1 » 18 Jul 2014 10:20
pz1 wrote: Edit 20140713: In the meantime I have returned my two FUS devices to my supplier who is kind enough to test both with his equipment.
Yesterday my supplier confirmed that both my Fibaro devices were working just fine with the Fibaro Home Center.
I guess the problem must somehow be with RaZberry
pz1
Post
by pz1 » 19 Jul 2014 09:58
pofs wrote: Unfortunately, the most relevant part of the log (MultiChannel interview) is beyond the quoted fragment. Need more log.
Hope you can find the time to have a look at the extended log part that I posted 10 days ago.
