OpenRemoteHelpers under version 2.0.0
pz1
Post by pz1 »
It seems that the OpenRemoteHelpers module is not working anymore under version 2.0.-rc8. I do get error message Invalid ZAutomation request
That can be tested with the WEBbrowser. For example I took command
http://raspberry:8083/ZAutomation/OpenRemote/TemperatureLevel/13/3
Which is supposed to read the temperature level of the fist sensor of the Fibaro FGBS001. This did work well in 1.7.2.
As a matter of fact none of OpenRemote calls does return a value. I guess the module needs adaptation for the new 2.0.0. Or can I find somewhere an update? I just use wgat comes with the RC.
pofs
Re: OpenRemoteHelpers under version 2.0.0
Post by pofs »
Yes, url access is changed in 2.0.
But you may fix it quite simple. Just add the following line in the end of OpenRemoteHelpers:
allowExternalAccess("OpenRemote");
And drop /ZAutomation part from the url, so it would be http://ip:8083/OpenRemote/
pz1
Post by pz1 »
I have added the allowExternalAccess at the end of the index.js of module OpenRemoteHelpers:
OpenRemoteHelpers.prototype.stop = function () {
    OpenRemoteHelpers.super_.prototype.stop.call(this);
    OpenRemote = null;
// --- Module methods
Restarted Z-Way server
Command http://raspberry:8083/OpenRemote/TemperatureLevel/15/3
reports now 404 Not Found
pofs
Post by pofs »
Has it even loaded? Do you have any errors in log?
I've tried to do the same, and it kinda works :)
Just not sure about response format, as strings like "on" and "off" are returned with quotes (default JSON serialization)
pz1
Post by pz1 »
Just got this solved: I did a complete reboot of the Pi :D
Apparantly restart Z-Way-server was not enough.
I have it working for Switches and Universal sensors. I am now confident to change all urls to my 10 StellaZ devices.
CPU usage seems the same as under 1.7, not yet the 1-2% predicted for release 2.x
PS: Shouldn't you guys add this line:
To the OpenRemoteHelpers JS file?
I'll make a prelimenary write-up of this transition from 1.x to 2.x under Recipes
pofs
Post by pofs »
Sure, we'll add it.
About CPU usage: 1-2% was measured on my laptop (against 3-4% on 1.7), not on RPi. Sure it would be a bit higher on RPi because of different architecture and computing power.
We don't have influence on resources used by v8 engine on a specific platform. Just watch mem and CPU usage isn't growing too much :)
pz1
Post by pz1 »
Can confirm that StellaZ main functions work fine now with OpenRemoteHelpers. There are a few minor functions e.g. device location/name that were in the old RaZOR module, which are (not yet) in the OpenRemoteHelpers.
You can add allowExternalAccess in OpenRemote module if you want to shorten URLs from /ZAutomation/OpenRemote to /OpenRemote.
@pofs: why allowExternalAccess is global and not in ws?
pz1
Post by pz1 »
On my own machine I have extended the index.js op OpenRemoteHelpers a bit. For my OR-GUI I do use devicename and location as they are stored in my StellaZ devices.
Just before case "metrics" I added:
            case "DeviceName":
                return zway.devices[N].instances[I].NodeNaming.data.nodename.value;
            case "DeviceLocation":
  			    return zway.devices[N].instances[I].NodeNaming.data.location.value;
By the way, what is the "metrics" suposed to do for me?
http://raspberry:8083/OpenRemote/metrics/21
Uncaught TypeError: Cannot read property 'get' of undefined
metrics are to fetch directly metrics from HA. Out /ZAutomation/api/v1/devices/StellaZ1 returns JSON object, while OpenRemote can not parse it. This 'metrics' is made ti fetch data from it.
