Starting HTTP server on port xxxx...
magadheera
Z-way v 1.7.0. After restarting the system z-way stucks here at Starting HTTP server on port xxxx..., and not moving further. Can anyone has the same problem. How to solve this problem.
Re: Starting HTTP server on port xxxx...
Did it work before? It is hard to say with the minimal information with the minimal info you have.
Version 1.7.0. is rather old. You advised to upgrade to 2.0, which is much more stable. That may not immediately solve your problem, but will be a better starting point
magadheera
Yes, it was working before. Sorry for the inconvinience to upgrade the sys will take some time. Feel better if some solution present for this prob with the same version.
It was working fine before, Just after restarting the sys it stops working.
attached screenshots from the z-way log.
- HTTP server on port error.png (63.42 KiB) Viewed 10067 times
Why is your log file specified to /bin/z-way-log????
magadheera
Frankly speaking,I dont know. This can be reason of this error?
It is at least a sign that you did not follow the standard installation procedure. So it is hard to guess. Besides not many users are on these older versions, so it will be hard to find someone who can repeat/check some of your issues.magadheera wrote:Frankly speaking,I dont know. This can be reason of this error?
If you do need to stay on this 1.7.0 version, I advise you to upload a zipped the relevant logfile here, so the experts can have a look.
magadheera
Here is compt log from the z-way.
magadheera
Here is compt log from the z-way. And one more thing i have noticed is that config.xml file is missing in this situation.
when i use cat config.xml, returns file not found error.
magadheera
Loading ZDDX index from /data/z-way/config/zddx/ZDDX.indxml
[2015-01-29 11:10:32.239] Failed to read ZDDX index
[2015-01-29 11:10:32.240] Failed to get a list of products. Check index file
Can please explain wht does above error means in Z-way.In my sys i dont have such file called ZDDX.indxml.
I have splittted log file, because of tits size.
- z-way003-log.zip
- Log 01
- (295.59 KiB) Downloaded 233 times
- z-way-log002.zip
- Log 02
- (277.46 KiB) Downloaded 220 times
- z-way-log001.zip
- Log 03
- (390.29 KiB) Downloaded 239 times
Sorry I do not see an attached log file attached to that postmagadheera wrote:Here is compt log from the z-way. And one more thing i have noticed is that config.xml file is missing in this situation.
