OK I've install z-way-server successfully and I want to remove old warning messages from <ip>:8083/z-way-ha
Is there any way to do this?
Clear log on z-way-ha
Re: Clear log on z-way-ha
Remove in folder automation/storage the file (name) that starts with notgifications. I think you have to reboot your device
Didn't work, warnings still there.
Also I don't think this is the correct file to remove because it return one more warning;
Failed to load module SensorsPolling because Cron was not instanciated
This was how I could do it in the past. Apparantly it does not allow that anymore. Thanks for the feedback.
I must leave the answer to the Zwave.Me team
My bad, you were right, I removed the config-something file.
Sorry
Sorry
Again, Thanks for the feedback
