With Whezzy on Pi with Razberry the system worked OK (3 Fibaro Roller Shutter FGRM-222, Motion Sensor FGMS-001).
After migration to Jessie and installation of z-way (21.11.2014 v2.0.0) I got the following error message in the logfile.
[2015-05-29 17:57:46.509] [I] [core] Executing script: /*** Z-Wave Binding module ******************************************************** ...
[2015-05-29 17:57:46.527] [I] [core] Instantiating module 2 from class ZWave
[2015-05-29 17:57:46.533] [I] [core] --- Starting module Z-Wave binding
[2015-05-29 17:57:46.604] [I] [core] Notification: critical (z-wave): Can not start Z-Wave binding: ReferenceError: ZWaveBinding is not defined
[2015-05-29 17:57:46.606] [I] [core] Loading module GroupDevices from modules/GroupDevices
[2015-05-29 17:57:46.610] [I] [core] Executing script: /*** GroupDevices Z-Way HA module ******************************************* ...
[2015-05-29 17:57:46.613] [I] [core] Loading module ScheduledScene from modules/ScheduledScene
[2015-05-29 17:57:46.618] [I] [core] Executing script: /*** ScheduledScene Z-Way HA module *******************************************
and got the following.LD_LIBRARY_PATH=libs ./z-way-server
But this command did not finish correctly, it hangs.Z-Way version v2.0.0 from 2014-12-08 19:54:26 +0300 (build a064f5408850947aed035bc9170e1fa04f0fd2ec)
Module moddhs.so loaded
Module modhomekit.so loaded
Module modenocean.so loaded
Module modhttp.so loaded
Module modws.so loaded
Failed to load module modzwave.so: libarchive.so.12: cannot open shared object file: No such file or directory
Trying to install libarchiv12 returns the following:
Possibly it is a problem of running ZWave on Jessie because I realized that with Jessie comes libarchive13.root@xxxxxxxxxxxxxxx2 19:32:27: / 4>apt-get install libarchive12
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
Package libarchive12 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'libarchive12' has no installation candidate
root@xxxxxxxxxxxxx2 19:32:43: / 5>
In /var/lib/dpkg/info/libarchive13:armhf.list one finds:
Whereas /var/lib/dpkg/info/libarchive12:armhf.list is empty./.
/usr
/usr/lib
/usr/lib/arm-linux-gnueabihf
/usr/lib/arm-linux-gnueabihf/libarchive.so.13.1.2
/usr/share
/usr/share/doc
/usr/share/doc/libarchive13
/usr/share/doc/libarchive13/copyright
/usr/share/doc/libarchive13/changelog.Debian.gz
/usr/share/lintian
/usr/share/lintian/overrides
/usr/share/lintian/overrides/libarchive13
After a lot of experiments and investigations I got the system running, but I am not sure whether this solution is clean, stable and complete.
I found in file "/opt/z-way-server/modules/modzwave.so the following content:
set_thread_name^@get_local_time_ms^@zio_read^@libarchive.so.12^@libstdc++.so.6^@libm.so.6^@libgcc_s.so.1
set_thread_name^@get_local_time_ms^@zio_read^@libarchive.so.13^@libstdc++.so.6^@libm.so.6^@libgcc_s.so.1
Is this a well known fact; is there already a newer version of z-way- server available ?
Any comment would be useful.
