Hi!
I'm currently working with the zway c-library to prototype some zwave functionality. I however have some problems scanning which command classes a particular device and instance supports.
I use the zway_devices_list -> zway_instances_list -> zway_command_classes_list to get information on what devices are available. (Is this an acceptable way to enumerate the device tree?)
Everything seems to work ok but for a particular device i don't get all command classes that is reported when i run the zway-server and the expert UI.
The device in question is an Aeotech Smart Switch. The above code reports the command classes
20 56 5e 72 86 98
while the expert UI says
"Basic, SwitchBinary, SwitchAll, SceneActivation, SceneActuatorConf, Meter, CRC16, AssociationGroupInformation, ZWavePlusInfo, Configuration, ManufacturerSpecific, PowerLevel, FirmwareUpdate, Association, Version, Security, "
How come i miss all these commandclasses when using zway_command_classes_list?
Code is loosely based on the example code provided for the clib api.
Enumerating command classes using the c-library fail
Re: Enumerating command classes using the c-library fail
Ok, the problem seems to be with me running two separate instances of the z-way stack. The config xml stores where out of sync and i where unable to do a NIF request/interview on the devices earlier enumerated by the zway-server.
When excluding the devices and then re-include them again i get sensible data back.
Hopefully i will be on my way with this now
Thanks for sharing your experiences. Not many work with the c-library, or at least don't report it here
Moderator
Moderator
Thanks and no problem.
To add on above comments, when the system works properly i also get nice, added events, callbacks upon start with all devices, instances and command classes.
Thus you most likely don't have to do the zway_devices_list -> zway_instances_list -> zway_command_classes_list traversal and instead just listen on the callbacks and build your shadow on the network topology.
/Tor
/Tor
