Hi guys,
I'm looking for a z-wave smoke sensor, at the moment I'm thinking about to buy the Fibaro FGSD-002, this is a new version, that fits some more EU/DIN standards. But I'm not sure, because I've seen problems with the older Fibaro Smoke Sensor.
So the question is: Are there known problems, is someone using it already? Or do you have some recommendations? I like the fact, that it has also a heat sensor. Also thought about to get a Popp/Devolo sensor.
Happy about all experiences and/or recommendations!
Thanks.
Smoke Sensor - recommendations?
Re: Smoke Sensor - recommendations?
Hi again,
I've bought the Fibaro FGSS-002 with EN14604 certification. Z-Way inclusion recognizes the sensor with out any problems, even a device description is available for the new 002 version in 2.0.2rc(-8). This is good, because it's very different to the 001 when you look for association groups and parameters. I'l test it a bit and give feedback.
Just a little "problem": it shows 9(!) alarm types and it's not absolutly clear what means what. Posted that already here.
Any questions can be posted here, I try to answer them.
AlphaX2
AlphaX2
I've included the smoke sensor FGSD-002. It works, however I've some difficulties wit the configuration.
There are 2 warnings:
Any idea how I can resolve this issue?Configuration Settings
Nº 1 - WAKE UP INTERVAL: Value was changed to 21600 but not stored in device yet.
Nº 5 - Sound notifications status: Value was changed to 0 but not stored in device yet.
I got this notification for all configuration points, solved it by manually waking up the sensor multiple times, by clicking the button and saving the options.
Thanks for your reply.
I got also the warnings for more parameters and I was able to remove all of them apart nr. 1 and 5.
I noticed that the device xml file was not the same as here http://pepper1.net/zwavedb/device/675/6 ... -03-02.xml
I downloaded this xml-file an replaced it in /opt/z-way-server/ZDDX but it didn't change anything.
What am I missing?
Edit:
Paramter Nº 1 - WAKE UP INTERVAL should be "Fibaro Smoke Sensor sensitivity"
What am I missing?
Edit:
... I'm updating the database (./UpdateXMLs.sh). Do you know how long it takes?
Okay - but both Xml files are wrong?!
In my case it's telling Parameter 1 set to "2" but it's also saying "Wake Up Interval". And as far as I remember all Parameter were set, but I also have a Notification for No. 5 at the moment. In Expert Commands section all Parameter are red and set 0 / None. :-/
Not long, just some seconds/minutes.flurin wrote:... I'm updating the database (./UpdateXMLs.sh). Do you know how long it takes?
hmm, it's running for 40 Minutes now! Probably not working properly.
I suspect, the Parameter Nr.1 should be removed, so that the parameters 2-5 are moved 1 step back. There is no parameter Nr. 5.
Edit: I started the shell as sudo, now it's running.
@AlphaX2 good news, after UpdateXMLs and RPi reboot the Configuration is OK, no warnings.
