maybe these questions are stupid but I can't figure it out on my own
1. Where is the Scene Creation module located ? I use up to date stable software of z-way but at the location which is described I can't find the scene creation option.
2. How can I create a device which runs external code (e.g. for Hue) ? Currently there is only an JS code application but nothing to run external code files
handon wrote:1. Where is the Scene Creation module located ? I use up to date stable software of z-way but at the location which is described I can't find the scene creation option.
Click on the top right corner "tool" symbol, and select Apps - Local apps. Look for this symbol:
Hard to say. It depends if you also want to interact from Z-Way with this external code, or if it just has to be started.
