Anyone out here who has tested the UPS Pico power backup board in combination with Zway + UZB1 stick on RaspberryPi?
It seems to gracefully shutdown after a powere outage, and reboots after power is restored. It also seems possible to detect if your system hangs.
UPDATE
In the longer term the UPS Pico proved to be unreliable. There seem to be problems with the firmware. I have sent mails and posts to the forum, but they just do not answer.
So my recommendation is NOT to invest in this device
UPS Pico experiences? (Do not use: Unreliable)
Re: UPS Pico experiences?
I did install it in the meantime on a RaspberryPi (no Zwave devices connected yet.). Since it is using the UART, I think it won't work with the RaZberry board.
edit: Do make sure you use a 2A power supply
The setup is a bit of an odyssey. The different pieces are not consistently written, and in some places outdated. Their server didn't allow me to wget some files as described in the instruction. Some files changed name. For example the firmware loader.
The product comes without any documentation. You have to get it from their site http://pimodules.com/. In the download section you do find the latest firmwares and all the code you need for the installation. To get full functionality the user needs to solder a "magic connection pin" to the board. That requires a very fine tipped soldering iron, and some soldering skills
I performed a successful manual firmware update to version 58 with command:
As said I haven't tested yet with Z-Wave devices added. It seems to do what it is supposed to do. I do hope to get fewer crashed SD cards in the future.
If you are going to buy this device, make sure you get hardware version HV1.1 or higher. The initial version is more complex to handle
sudo python picofu3.py -v -f UPS_PIco_0x58_18_01_2016.hexIf you are going to buy this device, make sure you get hardware version HV1.1 or higher. The initial version is more complex to handle
To see if the pi has crashed you don't really need this; the pi itself already has watchdog hardware, see https://www.domoticz.com/wiki/Setting_u ... i_watchdog on how to install it. This way you can auto reboot if anything goes wrong, it makes a home automation setup way more reliable. Also, don't use sd cards for a pi server, get a usb stick instead. I never have any data corruption issues.
Indeed.CopyCat73 wrote:To see if the pi has crashed you don't really need this
However if you are suffering from power spikes or power outages, imho the UPS function is useful. The largest available battery is specified for some 8 hours. That is likely to be less with an active Z-Wave controller I guess.
Make sure you apply sufficiently power to this Pi+UPS. I accidentally connected it to a 1A 5V power supply. The result was that the setup went into a power down start-up loop. I assume that the load current for the battery was too much for it. Reconnecting to the original 2A supply cured the problem
I tried using an adafruit powerboost 1000 with their recommended 2amp power supply and lithium battery.
(about $30 total)
I wanted something to be able to carry the RPi around the house when including wall switches, etc.
Looked good to start with, it kept the raspberry pi running while off wall power, but WiFi and Z-Wave communications totally broke down. Not sure if the power was dirty, or just not powerful enough.
(Running original RPi B)
(about $30 total)
Re: UPS Pico experiences? (Do not use: Unreliable)
In the end UPS Pico did not live up with the promises. I've updated first post accordingly.
Thanks for saving me some money pz1, what would you recommend in place of the UPS Pico?
The best probiotics for women are so effective.
I have no solution for it yet.
yo very helpfulVance wrote: ↑02 Sep 2016 09:00Thanks for saving me some money pz1, what would you recommend in place of the UPS Pico?pz1 wrote:
UPDATE
In the longer term the UPS Pico proved to be unreliable. There seem to be problems with the organifi firmware. I have sent mails and posts to the forum, but they just do not answer.
