Hi everyone,
are there any news about the community Module for HomeKit?
Would be nice to get some information about development state and when to expect it.
best regards,
vga
Community Module: HomeKit
Re: Community Module: HomeKit
Homebridge is not that hard to setup but I found it better to setup on a second raspberry pi rather than sharing with my Z-Way install. It worked on my rpi2 with both installed but the whole thing crashed after a few days. It's been runniing fine for a couple of weeks with Z-Way on the rpi2 and Homebridge on a rpiB+.
As an added bonus, there are modules for Nest and other devices as well as Z-Way which all integrate with Homebridge.
https://github.com/SphtKr/homebridge-zway
There's a little more setup involved to get this working than the function that used to be built into Z-way but Homekit seems to work much better with Homebridge.
yes, thanks for your answer.
i´ve set up a second rpi2 for homebridge with homebridge-zway plugin. ´
All works fine, even siri is working again!
I can also only recommend!
May I ask what versions you are using. I followed this guide: https://github.com/nfarina/homebridge/w ... spberry-Pi and installed z-way server 2.2.1, homebridge 0.2.8 and homebridge-zway 0.4.0. I get a parse error in my error log when I try to start the homebridge server. I cant however access the login api correctly. I just get this message: Uncaught TypeError: 'Cannot read property 'call' of undefined'
HI, can you please explain how you connected your homebridge to z-wave I am working on this last 2 days.vga wrote:yes, thanks for your answer.
Thanks.
Did you get yours working? I just got mine working two days ago.senad wrote: HI, can you please explain how you connected your homebridge to z-wave I am working on this last 2 days.
I also followed this guide:
