How to use Zipato mini keypad
Is there anyone that successfully go the mini keypad from Zipato to work with Razbarry? It is really unclear how to get it to work.
Re: How to use Zipato mini keypad
In the Online apps, there appears to be a module for it...
Interesting, does the app have a name?
"Trap events from Remotes and Sensors" There are some posts about this on the forum.Frixzon wrote:Interesting, does the app have a name?
Thanks i will look in to that app, i could't find anything when i searched the forum for Zipato mini keypad.
It did not go far for me... xp
After adding the keypad to Razberry a "Wintop Switch" appeared which i cant do much with. This switch can not be chosen by "Trap events from Remotes and Sensors" app. How do i do to add tags to trigger scenes etc?
How do i find these posts about configuring this keypad?
As a matter of fact, it does. Under ONLINE APPS (make sure you have selected ALL APPS, should be 50 or so), it shows up under the name: Zipato RFID Keypad.... App store can be a bit confusing until you get the hang of it...
Haha there it was! Thank you! =D
Now that you've found it, what is it capable of doing?
