Hi All, is there any one that can explain why, in the interview page of the zway configuration section (expert UI), choosing razberry as device id 1, I can not complete interview and I always read "Device seems to be dead"?
According to log file, after a Foce Interview call, I have
SETDATA devices.1.instances.0.commandClasses.152.data.interviewDone = False
[2016-04-18 06:03:58.527] [D] [zway] SETDATA devices.1.instances.0.commandClasses.152.data.interviewCounter = 9 (0x00000009)
[2016-04-18 06:03:58.528] [zway] Node 1:0 CC Security Interview started
[2016-04-18 06:03:58.528] [zway] Node 1:0 CC Security: sending Scheme Get
[2016-04-18 06:03:58.528] [E] [zway] Dropping packet to myself (node 1)
[2016-04-18 06:03:58.528] [E] [zway] Error returned from (command->cc->interview_handler)(zway, command): Not implemented by the library (-3)
Is this normal?
Marco
Static PC Controller Configuration
- Screen Shot
- Cattura.JPG (109.71 KiB) Viewed 10999 times
Marco
Re: Static PC Controller Configuration
Hi there,
since yesterday i would setup my raspberry new and install a fresh sd card, now i have the same problem.
Have you more information about the problem?
Raspberry PI with Z-Wave.me Board
2 x Fibaro Double Relay-Switch FGS 222
2 x Fibaro Shutter FGR 222
Fibaro Multi Sensor
Z-Wave.me RemoteControl
Fibaro Multi Sensor
It was a mistake, that only comes when you have no device included. It is a view problem.
When you look at controller information you can see that all is ok.
So include one device and then in the configuration list you can see the new device and all is fine.
Fibaro Multi Sensor
Fibaro Multi Sensor
For me it was not properly like this. At the moment I'have no more this reporting status (it disappeard on a previous upgrading) but in the past it was appearing even if I had 15-20 devices included. Probably there is a relation with the software release but I don't know the causes.
Marco
Are you trying to interview #1 from #1 ? it will not reach itself through radio
In fact the #1 selection in Configuration tab gices you no info. You don't need it. In latest Z-Way we have even decided to hide it not to frustrate users.
