Z-Way to MQTT
Re: Z-Way to MQTT
Wow! that's great, i will test this evening
Re: Z-Way to MQTT
I can't get it working with auth, but without it's woking like a charm!
Re: Z-Way to MQTT
I like this module but I am running into this in the log output:
[2016-07-19 20:04:16.576] [core] [MQTT_14] Error: Error: Message type error: 6
at MQTT.BaseModule.error (automation/userModules/BaseModule/index.js:122:17)
at null._errorCallback (automation/userModules/MQTT/index.js:103:8)
at MQTTClient._onError (automation/userModules/MQTT/lib/mqtt.js:442:10)
at MQTTClient._onData (automation/userModules/MQTT/lib/mqtt.js:468:14)
at tcp.connection.onrecv (automation/userModules/MQTT/lib/mqtt.js:322:10)
Re: Z-Way to MQTT
Don't know if the App-author is following this forum. You might raise a new issue on his Github space:
https://github.com/Edubits/Zway-MQTT
Re: Z-Way to MQTT
Hah, yeah, thanks for the reminder. I logged into GitHub to submit the issue and then got side tracked
Re: Z-Way to MQTT
Since you mentioned you got it working, I'm curious to see your set up. I have the MQTT module that this is based on working just fine, but if I upgrade to this one, I don't see my messages. I tried both with tags and with individual devices and neither seems to work.past wrote:I can't get it working with auth, but without it's woking like a charm!
But when I roll back to my older code it works fine.
Re: Z-Way to MQTT
I got this successfully working! Yay!
Not really sure what my issues were but this is up and running.
Re: Z-Way to MQTT
Just a custom UI i made with Node-RED and zway mqtt module.
- Spectacle.dT8788.png (33.96 KiB) Viewed 16491 times
Re: Z-Way to MQTT
@past,
Could you publish your MQTT flow? Could make a nice starter tuto for ZWay users.
Re: Z-Way to MQTT
My Node-RED flow: http://pastebin.com/SsgtiNBQ
Feel free to ask for any additional info.
I will make a tutorial later.
