Scene Activation to Main Controller (Life Line)
maddam
Post by maddam »
I am not sure how to sent Scene activation to main controller (Life Line).
zunoSendToGroupScene(CTRL_GROUP_1, 3); // Activate scene #3
Note: Real association groups number are shifted by one. Means CTRL_GROUP_1 is in reality number 2. This is because number 1 is Life Line group. Read more in description of Z-Wave implementation.
Does it mean, it is not possible to control main controller Life Line scene activation ?
Please could you provide example of scene activation together with various IDs sent based on button press to main controller ?
Means to have one button defined as simple switch and sent e.g. ID=14 for double click and 15 for triple click.
Z-uno transmision will be processed by next Lua code in main controller.
%% properties
30 sceneActivation
%% globals
local lightID = 30
local scene = fibaro:getValue(lightID, 'sceneActivation')
-- 16 == single click: ignore it - let light turn on and off as normal.
if (scene == '14') then -- double click
-- actions for double clicks go here
elseif (scene == '15') then -- tripple click
-- actions for tripple clicks go here
end
Re: Scene Activation to Main Controller (Life Line)
SceneActivation is sent only in the group you have defined, not in LL. Please add your controller in the corresponding group in addition to LL.
For examples:
1: #1 // LL - needed only to get reports via zunoSendReport()
2: #1 // CTRL_GROUP_1 with SceneAction commands
