i have a more or less stable running z-wave network with 14 connected devices (battery and mains powered).
I now want to move from Raspberry 2 to a Raspberry 3.
What steps do i have to take to make this move?
Is it enougth to take the SD Card and the Razberry Unit from the Raspberry 2 and put those into the raspberry 3?
Will the system run as before or do i have to setup a fresh Raspberry 3 and make the move device by device (exluding / including and do all the programming again).
The linux at my current raspberry 2 is a rapsbian linux (jessie), latest updates installed.
Regards,
BoxSon
How to change raspberry
Re: How to change raspberry
Nobody any idea?
Regards
Boxson
Regards
Boxson
I have never tried to move to Rpi 3, because there is very little to gain for me.
I did migrate from Raspberry PiB with RaZberry to Rpi2 with UZB quite a while ago. The recipe is here.
Use it at your own risk
theoretically, it should 'Just work' - the linux distro should still run and then pick up the razberry on the right port - I doubt there would be any harm giving it a go! Just move the SD and Razberry.
Sounds good, i'll give it a try. I wondered if anything around the z-way installation is connected to let's say the Raspis MAC-Address or so.
I'll report later.
Regards
Boxson
I'll report later.
Regards
Boxson
