This is my first post and I would like to say "Hello" and "Thanks" to all the people working on this project and, help people like me.
I used the "search" button before opening this topic, but I didn't found the solution ...
My razberry crashed after power fault so, I've removed the SD (because, after the zab files, it's my last backup)
I've installed (from scratch) a new instance with the latest version (v2.2.5) and restored from a .zab file but, didn't work.
From the web interface (not from Expert UI because I have only zab files) I got a pop-up with the message:
"Upload or restore of backup has failed"
and, in the log file I got:
"[E] [zway] Failed to open archive: Unrecognized archive format (-30)"
I've installed from scratch also the version v2.2.2 (was the version active at the moment of crash) and tried the same procedure but, the result is exactly the same.
I've tried also to restore other 2 previous backup files but, same error with all of them.
I've tried also to install the v2.2.2 and substitute the /opt/z-way-server folder with the one I have on the original SD but, I have the following message in the log:
[2016-12-20 16:30:40.457] [core] Starting ZWay Automation webserver
[2016-12-20 16:30:40.491] [E] [core] result: Error: SyntaxError: Unexpected token ,
at AutomationController.loadNotifications (automation/classes/AutomationController.js:1017:26)
at AutomationController.start (automation/classes/AutomationController.js:194:10)
at automation/main.js:102:16
Is there someone that can suggest something or that knows how I can restore my configuration and, with which version ?
Thanks a lot
