Hello everyone,
I'm having a strange problem. Today, my Z-Wave network seems to only work partially; so I had a look on the network map (see attachment). I'm using the following devices:
- Node 77: Mains-connected dimmer
- Node 78: Battery-operated (in deep sleep mode) Z-Uno
- Node 79: Battery-operated flood sensor (in deep sleep mode)
Now what puzzles me is that Node 77 seems to use a deeply sleeping battery device for its routes. That seems wrong, right? I've had the Z-Uno in ALWAYS_AWAKE mode for a short time for testing around a few days ago; however, in the Razberry configuration it now shows as deeply sleeping device.
Any ideas?
Battery device for routing?
- routing.png (18.29 KiB) Viewed 6136 times
Re: Battery device for routing?
This is why it is recommended to exclude Z-Uno and include back while changing type. Also presense of 78 as a neighbour of 77 is ok. This means 78 can use 77, but 77 should not use 78 (if 78 was marked as sleeping during inclusion)
